[Qgis-user] Labelin in export to DXF
L.W.
eaglelw at gmx.de
Tue Nov 10 10:13:25 PST 2020
I did it this way before and I examined the dxf again and found the
labeling :-)
it is very very very small ... I do have to zoom in very deep.
The hieght in QGIS is ~ 1.5 Map Units, in CAD it is 0.03m, the size is
1,2km.
How to bring the labeling bigger in DXF?
Regards
Am 10.11.2020 um 18:56 schrieb Zoltán Siki:
> Hello,
> labelling is not available in DXF export when you export a single
> layer. Try to export your project, Project / Import/Export / Export
> project to DXF...
> In lower part if the DXF Export window there is a checkbox "Export
> labels as MTEXT elements".
> Regards,
> Zoltan
> L.W. <eaglelw at gmx.de <mailto:eaglelw at gmx.de>> ezt Ãrta (idÅpont: 2020.
> nov. 10., K, 18:10):
> Hello,
> I am trying to export a project as DXF but to no avail.
> I.e. It works quite well, but I don't see the lettering on my drawn
> lines and points in the DXF, what do I have to set so that you can see
> it on the one hand and see it in an acceptable size in the DXF on
> the other.
> Everything looks exactly how I want it on the screen.
> (I do want to export the visible parts of a lot of layers.)
> I am grateful for every tip.
> Regards
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201110/4d4203b5/attachment-0001.html>
