[Qgis-user] Labelin in export to DXF
L.W.
eaglelw at gmx.de
Tue Nov 10 10:15:29 PST 2020
> The hieght in QGIS is ~ 1.5 Map Units, in CAD it is 0.03m, the size
is 1,2km.
The height in QGIS is ~ 1.5 Map Units, in CAD the labeling is 0.03m, the
size of the exported area is 1,2km.
regards
Am 10.11.2020 um 19:13 schrieb L.W.:
> I did it this way before and I examined the dxf again and found the
> labeling :-)
> it is very very very small ... I do have to zoom in very deep.
> The hieght in QGIS is ~ 1.5 Map Units, in CAD it is 0.03m, the size is
> 1,2km.
> How to bring the labeling bigger in DXF?
> Regards
> Am 10.11.2020 um 18:56 schrieb Zoltán Siki:
>> Hello,
>> labelling is not available in DXF export when you export a single
>> layer. Try to export your project, Project / Import/Export / Export
>> project to DXF...
>> In lower part if the DXF Export window there is a checkbox "Export
>> labels as MTEXT elements".
>> Regards,
>> Zoltan
>> L.W. <eaglelw at gmx.de <mailto:eaglelw at gmx.de>> ezt Ãrta (idÅpont:
>> 2020. nov. 10., K, 18:10):
>> Hello,
>> I am trying to export a project as DXF but to no avail.
>> I.e. It works quite well, but I don't see the lettering on my drawn
>> lines and points in the DXF, what do I have to set so that you
>> can see
>> it on the one hand and see it in an acceptable size in the DXF on
>> the other.
>> Everything looks exactly how I want it on the screen.
>> (I do want to export the visible parts of a lot of layers.)
>> I am grateful for every tip.
>> Regards
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201110/7599e962/attachment.html>
