[Qgis-user] Dynamic Line
Andreas Neumann
a.neumann at carto.net
Fri Nov 13 02:56:21 PST 2020
Yes, you need point data to start from, but then vectors can bei/are
generated from the attributes you mentioned.
Andreas
Am 13.11.20 um 11:47 schrieb L.W.:
> from the docs ...
> ****It can only be used to render point data****
> 12.2.2.2.6.The Vector Field Marker
> <https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?#id15>
> The vector field marker is used to display vector field data such as
> earth deformation, tidal flows, and the like. It displays the vectors
> as lines (preferably arrows) that are scaled and oriented according to
> selected attributes of data points. ****It can only be used to render
> point data****; line and polygon layers are not drawn by this symbology.
> The vector field is defined by attributes in the data, which can
> represent the field either by:
> *cartesian*components (|x|and|y|components of the field)
> or*polar*coordinates: in this case, attributes
> define|Length|and|Angle|. The angle may be measured either
> clockwise from north, or Counterclockwise from east, and may be
> either in degrees or radians.
> or as*height only*data, which displays a vertical arrow scaled
> using an attribute of the data. This is appropriate for displaying
> the vertical component of deformation, for example.
> The magnitude of field
> Am 13.11.2020 um 11:34 schrieb Andreas Neumann:
>> Or even easier: use the "Vector Field Marker":
>> https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?#the-vector-field-marker
>> Am 13.11.20 um 11:33 schrieb Andreas Neumann:
>>> Hi,
>>> Yes - you can use Geometry Generators for that. Use the make_point()
>>> and make_line() expressions for that.
>>> See
>>> https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?highlight=geometry%20generator#the-geometry-generator
>>> Greetings,
>>> Andreas
>>> Am 13.11.20 um 11:26 schrieb L.W.:
>>>> Hi,
>>>> is it possible to draw automatically a line between two points defined
>>>> by 4 fields (x1,y1 - x2,y2) in an attributetable?
>>>> but I do not want to add a line-layer based on this table nor want to
>>>> draw the line by hand.
>>>> thanks
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201113/0ae1e76d/attachment.html>
