[Qgis-user] Dynamic Line
L.W. eaglelw at gmx.de
Fri Nov 13 05:52:37 PST 2020
Does it works on Layers with no geometry?
My layers do not have a geometry.
Am 13.11.2020 um 11:56 schrieb Andreas Neumann:
> Yes, you need point data to start from, but then vectors can bei/are
> generated from the attributes you mentioned.
> Andreas
> Am 13.11.20 um 11:47 schrieb L.W.:
>> from the docs ...
>> ****It can only be used to render point data****
>>         12.2.2.2.6.The Vector Field Marker
>>         <https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?#id15>
>> The vector field marker is used to display vector field data such as
>> earth deformation, tidal flows, and the like. It displays the vectors
>> as lines (preferably arrows) that are scaled and oriented according
>> to selected attributes of data points. ****It can only be used to
>> render point data****; line and polygon layers are not drawn by this
>> symbology.
>> The vector field is defined by attributes in the data, which can
>> represent the field either by:
>>     *cartesian*components (|x|and|y|components of the field)
>>     or*polar*coordinates: in this case, attributes
>>     define|Length|and|Angle|. The angle may be measured either
>>     clockwise from north, or Counterclockwise from east, and may be
>>     either in degrees or radians.
>>     or as*height only*data, which displays a vertical arrow scaled
>>     using an attribute of the data. This is appropriate for
>>     displaying the vertical component of deformation, for example.
>> The magnitude of field
>> Am 13.11.2020 um 11:34 schrieb Andreas Neumann:
>>> Or even easier: use the "Vector Field Marker":
>>> https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?#the-vector-field-marker
>>> Am 13.11.20 um 11:33 schrieb Andreas Neumann:
>>>> Hi,
>>>> Yes - you can use Geometry Generators for that. Use the
>>>> make_point() and make_line() expressions for that.
>>>> See
>>>> https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?highlight=geometry%20generator#the-geometry-generator
>>>> Greetings,
>>>> Andreas
>>>> Am 13.11.20 um 11:26 schrieb L.W.:
>>>>> Hi,
>>>>> is it possible to draw automatically a line between two points
>>>>> defined
>>>>> by 4 fields (x1,y1 - x2,y2) in an attributetable?
>>>>> but I do not want to add a line-layer based on this table nor want to
>>>>> draw the line by hand.
>>>>> thanks
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201113/6e8a44e6/attachment.html>
