[Qgis-user] Add Layer Search to Toolbar
Richard Duivenvoorde
rdmailings at duif.net
Fri Nov 13 07:37:16 PST 2020
Have a look in the settings/configure (right mouse context in the locator bar).
With f ... you search in current active layer
With f @columname you search in the values of 'columname' in current active layer
(same with 'af' but then for all layers)
See https://docs.qgis.org/3.16/en/docs/user_manual/introduction/qgis_configuration.html#locator-settings
Hope this helps
Regards,
On 11/13/20 4:30 PM, L.W. wrote:
> no, I have never used it, but, there are a hugh list of layers in my project and it seemed that I can not search in a specific layer.
> I only need result of one field displayed in a text field.
> Am 13.11.2020 um 16:24 schrieb Jorge Gustavo Rocha:
>> Hi L.W.,
>> You already have a search toolbar, at the lower left corner. There are several search options. Have you tried them?
>> Regards,
>> Jorge Gustavo
>> Ãs 14:39 de 13/11/20, L.W. escreveu:
>>> Hi,
>>> is there a default option / way to have a textfield for searching in a
>>> layer at the toolbar (or dock-window)? Ill like to get the
>>> "fieldname"-value of the found dataset / attribute.
>>> regards
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Email Signature
>> Logo <https://www.geomaster.pt>
>> *Geomaster*
>> *Jorge Gustavo Rocha* | Software Engineer
>> *e:*jgr at geomaster.pt | *m:*+351 910 333 888
>> *g:*41.54094,-8.40490 | *v: *510 906 109
>> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
