[Qgis-user] Add Layer Search to Toolbar
L.W.
eaglelw at gmx.de
Fri Nov 13 07:43:30 PST 2020
and this is the point:
"With f @columname you search in the values of 'columname' in current
active layer"
I do want to search every time independant of the active layer ... and
the search-field is not the result-field I need.
Am 13.11.2020 um 16:37 schrieb Richard Duivenvoorde:
> Have a look in the settings/configure (right mouse context in the locator bar).
> With f ... you search in current active layer
> With f @columname you search in the values of 'columname' in current active layer
> (same with 'af' but then for all layers)
> See https://docs.qgis.org/3.16/en/docs/user_manual/introduction/qgis_configuration.html#locator-settings
> Hope this helps
> Regards,
> On 11/13/20 4:30 PM, L.W. wrote:
>> no, I have never used it, but, there are a hugh list of layers in my project and it seemed that I can not search in a specific layer.
>> I only need result of one field displayed in a text field.
>> Am 13.11.2020 um 16:24 schrieb Jorge Gustavo Rocha:
>>> Hi L.W.,
>>> You already have a search toolbar, at the lower left corner. There are several search options. Have you tried them?
>>> Regards,
>>> Jorge Gustavo
>>> Ãs 14:39 de 13/11/20, L.W. escreveu:
>>>> Hi,
>>>> is there a default option / way to have a textfield for searching in a
>>>> layer at the toolbar (or dock-window)? Ill like to get the
>>>> "fieldname"-value of the found dataset / attribute.
>>>> regards
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Email Signature
>>> Logo <https://www.geomaster.pt>
>>> *Geomaster*
>>> *Jorge Gustavo Rocha* | Software Engineer
>>> *e:*jgr at geomaster.pt | *m:*+351 910 333 888
>>> *g:*41.54094,-8.40490 | *v: *510 906 109
>>> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
