[Qgis-user] Add Layer Search to Toolbar
Richard Duivenvoorde
rdmailings at duif.net
Fri Nov 13 07:52:08 PST 2020
Please describe your use-case more specific.
What is the end result you want:
- a location?
- a value of a record (but not the one you search for?
Can you use the filter function in the table? And maybe dock the table as a dockwidget?
Can you implement a 'locator' yourself (python coding)?
Or else write a small plugin for this?
Regards,
Richard
On 11/13/20 4:43 PM, L.W. wrote:
> and this is the point:
> "With f @columname you search in the values of 'columname' in current
> active layer"
> I do want to search every time independant of the active layer ... and
> the search-field is not the result-field I need.
> Am 13.11.2020 um 16:37 schrieb Richard Duivenvoorde:
>> Have a look in the settings/configure (right mouse context in the locator bar).
>> With f ... you search in current active layer
>> With f @columname you search in the values of 'columname' in current active layer
>> (same with 'af' but then for all layers)
>> See https://docs.qgis.org/3.16/en/docs/user_manual/introduction/qgis_configuration.html#locator-settings
>> Hope this helps
>> Regards,
>> On 11/13/20 4:30 PM, L.W. wrote:
>>> no, I have never used it, but, there are a hugh list of layers in my project and it seemed that I can not search in a specific layer.
>>> I only need result of one field displayed in a text field.
>>> Am 13.11.2020 um 16:24 schrieb Jorge Gustavo Rocha:
>>>> Hi L.W.,
>>>> You already have a search toolbar, at the lower left corner. There are several search options. Have you tried them?
>>>> Regards,
>>>> Jorge Gustavo
>>>> Às 14:39 de 13/11/20, L.W. escreveu:
>>>>> Hi,
>>>>> is there a default option / way to have a textfield for searching in a
>>>>> layer at the toolbar (or dock-window)? Ill like to get the
>>>>> "fieldname"-value of the found dataset / attribute.
>>>>> regards
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Email Signature
>>>> Logo <https://www.geomaster.pt>
>>>> *Geomaster*
>>>> *Jorge Gustavo Rocha* | Software Engineer
>>>> *e:*jgr at geomaster.pt | *m:*+351 910 333 888
>>>> *g:*41.54094,-8.40490 | *v: *510 906 109
>>>> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
