[Qgis-user] Add Layer Search to Toolbar
L.W.
eaglelw at gmx.de
Fri Nov 13 07:58:26 PST 2020
Use-Case:
I add a Point on map, the attribute-editor opens and I give some Data to it.
want-to-have:
I want to add a foreign-Key id, but can not add a search-form in this
gui. so my idea was to search in the foreign table with a search-term
and get the id of the found row.
with this id I can add the new point.
my biggest problem, I do not like python as much ... I can write
'python' but none line of code ;-)
Am 13.11.2020 um 16:52 schrieb Richard Duivenvoorde:
> Please describe your use-case more specific.
> What is the end result you want:
> - a location?
> - a value of a record (but not the one you search for?
> Can you use the filter function in the table? And maybe dock the table as a dockwidget?
> Can you implement a 'locator' yourself (python coding)?
> Or else write a small plugin for this?
> Regards,
> Richard
> On 11/13/20 4:43 PM, L.W. wrote:
>> and this is the point:
>> "With f @columname you search in the values of 'columname' in current
>> active layer"
>> I do want to search every time independant of the active layer ... and
>> the search-field is not the result-field I need.
>> Am 13.11.2020 um 16:37 schrieb Richard Duivenvoorde:
>>> Have a look in the settings/configure (right mouse context in the locator bar).
>>> With f ... you search in current active layer
>>> With f @columname you search in the values of 'columname' in current active layer
>>> (same with 'af' but then for all layers)
>>> See https://docs.qgis.org/3.16/en/docs/user_manual/introduction/qgis_configuration.html#locator-settings
>>> Hope this helps
>>> Regards,
>>> On 11/13/20 4:30 PM, L.W. wrote:
>>>> no, I have never used it, but, there are a hugh list of layers in my project and it seemed that I can not search in a specific layer.
>>>> I only need result of one field displayed in a text field.
>>>> Am 13.11.2020 um 16:24 schrieb Jorge Gustavo Rocha:
>>>>> Hi L.W.,
>>>>> You already have a search toolbar, at the lower left corner. There are several search options. Have you tried them?
>>>>> Regards,
>>>>> Jorge Gustavo
>>>>> Ãs 14:39 de 13/11/20, L.W. escreveu:
>>>>>> Hi,
>>>>>> is there a default option / way to have a textfield for searching in a
>>>>>> layer at the toolbar (or dock-window)? Ill like to get the
>>>>>> "fieldname"-value of the found dataset / attribute.
>>>>>> regards
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Email Signature
>>>>> Logo <https://www.geomaster.pt>
>>>>> *Geomaster*
>>>>> *Jorge Gustavo Rocha* | Software Engineer
>>>>> *e:*jgr at geomaster.pt | *m:*+351 910 333 888
>>>>> *g:*41.54094,-8.40490 | *v: *510 906 109
>>>>> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
