[Qgis-user] Historical data in QGIS-PostGIS
Paolo Cavallini
cavallini at faunalia.it
Sat Nov 14 00:20:18 PST 2020
Have you tried the versioning command in db manager?
Cheers.
On 14 November 2020 08:47:08 CET, Richard Duivenvoorde <rdmailings at duif.net> wrote:
>On 11/14/20 12:11 AM, Vanildo Heleno Pereira wrote:
>> Hello everyone.
>> I would like to know if there is a possibility to work with
>historical versions of geographic data in QGIS / PostGIS?
>> The geometries need to be stored in a single database table
>(PostgreSQL) and you will receive data (new records from the same
>location) annually and I need to visualize each one in a different
>layer.
>Hi Vanildo,
>What do you mean with 'historical version of geographical data'?
>Is it that you have different versions of a certain geometric feature
>(be it a border, a street or an animal), and that versions actually has
>(should have) 2 (date)time columns, being 'first appearance' and 'last
>appearance'?
>If so, this kind of data is to be viewed in a sort of 'time-frames'?
>So say you have a set of streetdata, you could show a layer as: show me
>streets all streets of 1800-1900 as a dataset in which you have a
>filter like (first_appeareance > 1800 AND < 1900) or (last_appearance >
>1800 AND < 1900) (or variations like this).
>Then you can create views in the database with these filter queries,
>but you can also do that in different layers in QGIS (both if you want
>to be able to show different timeframes at a time)
>You could also do this using the 'temporal controller' which is now in
>QGIS, then you kan keep it one layer and use the controller to show one
>certain 'time frame' at a time.
>Or do I misunderstand you question?
>Regards,
>_______________________________________________
>Qgis-user mailing list
>Qgis-user at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201114/f6d4f214/attachment.html>
