[Qgis-user] Problem exporting to pdf
António Pestana afsm.pestana at gmail.com
Sat Nov 14 12:32:59 PST 2020
I´m using QGIS Desktop 3.16 on W10. My project (see All_Data.zip) has
only two shapefile layers, one for polygons (Todas as Parcelas Áreas)
and the other for lines (Todas as Parcelas Linhas). I used a very
simple layout for exporting my map to one layered geopdf. If I use the
default export options (see Options_NOT_OK.PNG) export aborts throwing
the "Could not create print device" error. However if I uncheck the
"Include Attributes" checkbox of the export options (see
options_OK.PNG), the export is made and the resulting pdf file looks
fine.... Does someone know what is happening?
Regards
António
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201114/7c9c6a48/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201114/7c9c6a48/attachment-0003.png>
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201114/7c9c6a48/attachment-0001.bin>
