[Qgis-user] Dynamic Line
L.W.
eaglelw at gmx.de
Sat Nov 14 04:53:25 PST 2020
I tried a lot ...
I have a point-layer, I put this code in symbol -> single symbol ->
geometrygenerator
What is wrong?
geom_to_wkt
   make_line
      make_point
         5826542.703128459,
         797907.3304607988
      make_point
         5827473.536854242,
         796987.0074038045
      make_point
         5827167.893279332,
         795128.2317764781
      make_point
         5826835.7783904355,
         793227.8583700341
Am 13.11.2020 um 15:24 schrieb Andreas Neumann:
> Hi Nicolas,
> Yes - but that doesn't magically turn a "non geometry" table into a
> "geometry table" - as far as I know. So you probably need to create a
> "Virtual Layer" and create the geometry similar to what you propose.
> Andreas
> Am 13.11.20 um 15:22 schrieb Nicolas Cadieux:
>> Hi,
>> You can create a geometry from WKT if you have x and y fields using
>> and expression in the field calculator.
>> |geom_from_wkt('POINT('||"x"||' '||"y"||')')|
>> https://en.wikipedia.org/wiki/Well-known_text_representation_of_geometry
>> Nicolas Cadieux
>>> Le 13 nov. 2020 à 09:07, Andreas Neumann <a.neumann at carto.net> a écrit :
>>> Hi
>>> Neither GeometryGenerators nor Vector Field Markers work on tables
>>> without geometry, unfortunately. You didn't inform us, that you
>>> don't have geometry in your table.
>>> You can, however, create a "Virtual Layer" and write some SQL to
>>> create a geometry from your attributes: menu "Layer" --> "Create
>>> Layer" --> "New Virtual Layer" - where you can use your existing
>>> tables and create a new geometry column with SQL. See
>>> https://docs.qgis.org/testing/en/docs/user_manual/managing_data_source/create_layers.html#creating-virtual-layers
>>> Or, if your table is a CSV file, then you can assign attribute
>>> columns to a point geometry and then just hide the point rendering
>>> if you don't need it.
>>> This is an unfortunate limitation of QGIS, that there is no "easy"
>>> way to add a geometry column to table that doesn't have geometry (or
>>> if it is possible, then I don't know it).
>>> Hope this helps you,
>>> Andreas
>>> Am 13.11.20 um 14:52 schrieb L.W.:
>>>> Does it works on Layers with no geometry?
>>>> My layers do not have a geometry.
>>>> Am 13.11.2020 um 11:56 schrieb Andreas Neumann:
>>>>> Yes, you need point data to start from, but then vectors can
>>>>> bei/are generated from the attributes you mentioned.
>>>>> Andreas
>>>>> Am 13.11.20 um 11:47 schrieb L.W.:
>>>>>> from the docs ...
>>>>>> ****It can only be used to render point data****
>>>>>> 12.2.2.2.6.The Vector Field Marker
>>>>>> <https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?#id15>
>>>>>> The vector field marker is used to display vector field data such
>>>>>> as earth deformation, tidal flows, and the like. It displays the
>>>>>> vectors as lines (preferably arrows) that are scaled and oriented
>>>>>> according to selected attributes of data points. ****It can only
>>>>>> be used to render point data****; line and polygon layers are not
>>>>>> drawn by this symbology.
>>>>>> The vector field is defined by attributes in the data, which can
>>>>>> represent the field either by:
>>>>>> *cartesian*components (|x|and|y|components of the field)
>>>>>> or*polar*coordinates: in this case, attributes
>>>>>> define|Length|and|Angle|. The angle may be measured either
>>>>>> clockwise from north, or Counterclockwise from east, and may
>>>>>> be either in degrees or radians.
>>>>>> or as*height only*data, which displays a vertical arrow
>>>>>> scaled using an attribute of the data. This is appropriate
>>>>>> for displaying the vertical component of deformation, for
>>>>>> example.
>>>>>> The magnitude of field
>>>>>> Am 13.11.2020 um 11:34 schrieb Andreas Neumann:
>>>>>>> Or even easier: use the "Vector Field Marker":
>>>>>>> https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?#the-vector-field-marker
>>>>>>> Am 13.11.20 um 11:33 schrieb Andreas Neumann:
>>>>>>>> Hi,
>>>>>>>> Yes - you can use Geometry Generators for that. Use the
>>>>>>>> make_point() and make_line() expressions for that.
>>>>>>>> See
>>>>>>>> https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?highlight=geometry%20generator#the-geometry-generator
>>>>>>>> Greetings,
>>>>>>>> Andreas
>>>>>>>> Am 13.11.20 um 11:26 schrieb L.W.:
>>>>>>>>> Hi,
>>>>>>>>> is it possible to draw automatically a line between two points
>>>>>>>>> defined
>>>>>>>>> by 4 fields (x1,y1 - x2,y2) in an attributetable?
>>>>>>>>> but I do not want to add a line-layer based on this table nor
>>>>>>>>> want to
>>>>>>>>> draw the line by hand.
>>>>>>>>> thanks
>>>>>>>>> _______________________________________________
>>>>>>>>> Qgis-user mailing list
>>>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201114/1e7a4a3e/attachment-0001.html>
