[Qgis-user] Dynamic Line
    L.W.
    eaglelw at gmx.de
    Sat Nov 14 05:00:41 PST 2020
Selected Geometrietype: LineString / MultLineString
Am 14.11.2020 um 13:53 schrieb L.W.:
> I tried a lot ...
> I have a point-layer, I put this code in symbol -> single symbol ->
> geometrygenerator
> What is wrong?
> geom_to_wkt
>     make_line
>         make_point
>             5826542.703128459,
>             797907.3304607988
>         make_point
>             5827473.536854242,
>             796987.0074038045
>         make_point
>             5827167.893279332,
>             795128.2317764781
>         make_point
>             5826835.7783904355,
>             793227.8583700341
> Am 13.11.2020 um 15:24 schrieb Andreas Neumann:
>> Hi Nicolas,
>> Yes - but that doesn't magically turn a "non geometry" table into a
>> "geometry table" - as far as I know. So you probably need to create a
>> "Virtual Layer" and create the geometry similar to what you propose.
>> Andreas
>> Am 13.11.20 um 15:22 schrieb Nicolas Cadieux:
>>> Hi,
>>> You can create a geometry from WKT if you have x and y fields using
>>> and expression in the field calculator.
>>> |geom_from_wkt('POINT('||"x"||' '||"y"||')')|
>>> https://en.wikipedia.org/wiki/Well-known_text_representation_of_geometry
>>> Nicolas Cadieux
>>>> Le 13 nov. 2020 à 09:07, Andreas Neumann <a.neumann at carto.net> a
>>>> écrit :
>>>> Hi
>>>> Neither GeometryGenerators nor Vector Field Markers work on tables
>>>> without geometry, unfortunately. You didn't inform us, that you
>>>> don't have geometry in your table.
>>>> You can, however, create a "Virtual Layer" and write some SQL to
>>>> create a geometry from your attributes: menu "Layer" --> "Create
>>>> Layer" --> "New Virtual Layer" - where you can use your existing
>>>> tables and create a new geometry column with SQL. See
>>>> https://docs.qgis.org/testing/en/docs/user_manual/managing_data_source/create_layers.html#creating-virtual-layers
>>>> Or, if your table is a CSV file, then you can assign attribute
>>>> columns to a point geometry and then just hide the point rendering
>>>> if you don't need it.
>>>> This is an unfortunate limitation of QGIS, that there is no "easy"
>>>> way to add a geometry column to table that doesn't have geometry
>>>> (or if it is possible, then I don't know it).
>>>> Hope this helps you,
>>>> Andreas
>>>> Am 13.11.20 um 14:52 schrieb L.W.:
>>>>> Does it works on Layers with no geometry?
>>>>> My layers do not have a geometry.
>>>>> Am 13.11.2020 um 11:56 schrieb Andreas Neumann:
>>>>>> Yes, you need point data to start from, but then vectors can
>>>>>> bei/are generated from the attributes you mentioned.
>>>>>> Andreas
>>>>>> Am 13.11.20 um 11:47 schrieb L.W.:
>>>>>>> from the docs ...
>>>>>>> ****It can only be used to render point data****
>>>>>>>         12.2.2.2.6.The Vector Field Marker
>>>>>>>         <https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?#id15>
>>>>>>> The vector field marker is used to display vector field data
>>>>>>> such as earth deformation, tidal flows, and the like. It
>>>>>>> displays the vectors as lines (preferably arrows) that are
>>>>>>> scaled and oriented according to selected attributes of data
>>>>>>> points. ****It can only be used to render point data****; line
>>>>>>> and polygon layers are not drawn by this symbology.
>>>>>>> The vector field is defined by attributes in the data, which can
>>>>>>> represent the field either by:
>>>>>>>     *cartesian*components (|x|and|y|components of the field)
>>>>>>>     or*polar*coordinates: in this case, attributes
>>>>>>>     define|Length|and|Angle|. The angle may be measured either
>>>>>>>     clockwise from north, or Counterclockwise from east, and may
>>>>>>>     be either in degrees or radians.
>>>>>>>     or as*height only*data, which displays a vertical arrow
>>>>>>>     scaled using an attribute of the data. This is appropriate
>>>>>>>     for displaying the vertical component of deformation, for
>>>>>>>     example.
>>>>>>> The magnitude of field
>>>>>>> Am 13.11.2020 um 11:34 schrieb Andreas Neumann:
>>>>>>>> Or even easier: use the "Vector Field Marker":
>>>>>>>> https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?#the-vector-field-marker
>>>>>>>> Am 13.11.20 um 11:33 schrieb Andreas Neumann:
>>>>>>>>> Hi,
>>>>>>>>> Yes - you can use Geometry Generators for that. Use the
>>>>>>>>> make_point() and make_line() expressions for that.
>>>>>>>>> See
>>>>>>>>> https://docs.qgis.org/3.10/en/docs/user_manual/style_library/symbol_selector.html?highlight=geometry%20generator#the-geometry-generator
>>>>>>>>> Greetings,
>>>>>>>>> Andreas
>>>>>>>>> Am 13.11.20 um 11:26 schrieb L.W.:
>>>>>>>>>> Hi,
>>>>>>>>>> is it possible to draw automatically a line between two
>>>>>>>>>> points defined
>>>>>>>>>> by 4 fields (x1,y1 - x2,y2) in an attributetable?
>>>>>>>>>> but I do not want to add a line-layer based on this table nor
>>>>>>>>>> want to
>>>>>>>>>> draw the line by hand.
>>>>>>>>>> thanks
>>>>>>>>>> _______________________________________________
>>>>>>>>>> Qgis-user mailing list
>>>>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201114/9b632313/attachment.html>
