[Qgis-user] I finally broke my QGIS
Steve Cook
bigskymapping1 at gmail.com
Tue Nov 17 14:40:24 PST 2020
I installed the latest version (but 3.14 was also not working). Basically
no gdal functionality. Any clues greatly appreciated.
Thanks,
Steve
QGIS version: 3.16.0-Hannover
QGIS code revision: 43b64b13f3
Qt version: 5.11.2
GDAL version: 3.1.4
GEOS version: 3.8.1-CAPI-1.13.3
PROJ version: Rel. 6.3.2, May 1st, 2020
Processing algorithmâ¦
Algorithm 'Raster information' startingâ¦
Input parameters:
{ 'EXTRA' : '', 'INPUT' :
'C:/Tensorflow/land-use-classification-cnn-master/2750/Sentinel/StMarg_26607.jpg',
'MIN_MAX' : False, 'NOGCP' : False, 'NO_METADATA' : False, 'OUTPUT' :
'TEMPORARY_OUTPUT', 'STATS' : False }
GDAL command:
gdalinfo
GDAL command output:
'gdalinfo' is not recognized as an internal or external command,
operable program or batch file.
Execution completed in 0.09 seconds
Results:
{'OUTPUT':
'C:/Users/user/AppData/Local/Temp/processing_WYDWfJ/09bec4435ae2407290e93fde33b16905/OUTPUT.html'}
Loading resulting layers
Algorithm 'Raster information' finished
HTML output has been generated by this algorithm.
Open the results dialog to check it.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201117/f71840a5/attachment.html>
