[Qgis-user] I finally broke my QGIS
Nicolas Cadieux njacadieux.gitlab at gmail.com
Tue Nov 17 14:49:46 PST 2020
I would try reset your personal profile.  If that does not work, I would do a complete reinstall since your problems seem to pass from one version to another. It would help developer if you indicated what installer and operating system you are using.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 17 nov. 2020 à 17:41, Steve Cook <bigskymapping1 at gmail.com> a écrit :
> I installed the latest version (but 3.14 was also not working). Basically no gdal functionality. Any clues greatly appreciated.
> Thanks,
> Steve
> QGIS version: 3.16.0-Hannover
> QGIS code revision: 43b64b13f3
> Qt version: 5.11.2
> GDAL version: 3.1.4
> GEOS version: 3.8.1-CAPI-1.13.3
> PROJ version: Rel. 6.3.2, May 1st, 2020
> Processing algorithm…
> Algorithm 'Raster information' starting…
> Input parameters:
> { 'EXTRA' : '', 'INPUT' : 'C:/Tensorflow/land-use-classification-cnn-master/2750/Sentinel/StMarg_26607.jpg', 'MIN_MAX' : False, 'NOGCP' : False, 'NO_METADATA' : False, 'OUTPUT' : 'TEMPORARY_OUTPUT', 'STATS' : False }
> GDAL command:
> gdalinfo C:\Tensorflow\land-use-classification-cnn-master\2750\Sentinel\StMarg_26607.jpg
> GDAL command output:
> 'gdalinfo' is not recognized as an internal or external command,
> operable program or batch file.
> Execution completed in 0.09 seconds
> Results:
> {'OUTPUT': 'C:/Users/user/AppData/Local/Temp/processing_WYDWfJ/09bec4435ae2407290e93fde33b16905/OUTPUT.html'}
> Loading resulting layers
> Algorithm 'Raster information' finished
> HTML output has been generated by this algorithm.
> Open the results dialog to check it.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201117/ad945938/attachment.html>
