[Qgis-user] Vote for Lat Lon Tools Default Coordinate Order - YX or XY
    Ujaval Gandhi
    ujaval at spatialthoughts.com
    Fri Nov 20 09:44:00 PST 2020
I generally use Lat Lon Tools to go to a specific coordinate that I found
somewhere (online maps, Wikipedia etc.) - so latitude, longitude is
preferred. There are other use cases where X,Y is preferred, but I have
always found it easy to switch using settings or dropdown menu when needed.
Thanks for authoring and maintaining a great plugin!
[image: Logo] <https://spatialthoughts.com/>
Ujaval Gandhi
Spatial Thoughts
mobile: +91-8095684687
email: ujaval at spatialthoughts.com
[image: LinkedIn icon] <https://www.linkedin.com/in/spatialthoughts/>  [image:
Twitter icon] <https://twitter.com/spatialthoughts>
On Fri, Nov 20, 2020 at 10:41 PM C Hamilton <adenaculture at gmail.com> wrote:
> It was suggested to me that the default coordinate order in the Lat Lon
> Tools plugin for coordinate capture and zoom-to tools should be "longitude,
> latitude" or "X, Y". Originally, Lat Lon Tools was designed to work with
> on-line maps which are generally "latitude, longitude" order.
> You can always go into the plugin settings and specify which order you
> want and that order will be preserved everytime you launch QGIS. The
> default order is only applicable the first time you install "Lat Lon Tools"
> or if you do a reset to defaults in the Lat Lon Tools settings menu,
> Who prefers Lat Lon Tools to default to "longitude, latitude" or "X, Y"
> when the plugin is first installed or reset to default values?
> Who prefers Lat Lon Tools to default to "latitude, longitude (Google map
> order)" or "Y, X" when the plugin is first installed or reset to default
> values?
> I'm just checking to see if I should make this change or not.
> Thanks,
> Calvin
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201120/5140f7e2/attachment.html>
