[Qgis-user] Vote for Lat Lon Tools Default Coordinate Order - YX or XY
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Fri Nov 20 10:16:49 PST 2020
I would default to the name of the tool. Lat Lon. This way, we can more easily remember.
As a side note, being dyslexic (and getting stuff like left and right wrong 25% of the time!), I always like when I also see things like N, W or x,y or row col, besides lat Lon in the GUI just to get additional visual cues as to what i’am processing.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 20 nov. 2020 à 12:11, C Hamilton <adenaculture at gmail.com> a écrit :
> It was suggested to me that the default coordinate order in the Lat Lon Tools plugin for coordinate capture and zoom-to tools should be "longitude, latitude" or "X, Y". Originally, Lat Lon Tools was designed to work with on-line maps which are generally "latitude, longitude" order.
> You can always go into the plugin settings and specify which order you want and that order will be preserved everytime you launch QGIS. The default order is only applicable the first time you install "Lat Lon Tools" or if you do a reset to defaults in the Lat Lon Tools settings menu,
> Who prefers Lat Lon Tools to default to "longitude, latitude" or "X, Y" when the plugin is first installed or reset to default values?
> Who prefers Lat Lon Tools to default to "latitude, longitude (Google map order)" or "Y, X" when the plugin is first installed or reset to default values?
> I'm just checking to see if I should make this change or not.
> Thanks,
> Calvin
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201120/b28cbf67/attachment.html>
