[Qgis-user] Vote for Lat Lon Tools Default Coordinate Order -, YX or XY
Mike Flannigan mflan at mflan.com
Fri Nov 20 15:44:55 PST 2020
I too like lat,long, but I can live with anything that is done.
I'll just set it to lat,long.
I understand the thinking to change it to X,Y.  Many people
in the field would agree that is better.  I'm just not one of them.
I use this tool constantly.  Thank you.
Mike
On 11/20/20 2:00 PM, qgis-user-request at lists.osgeo.org wrote:
> It was suggested to me that the default coordinate order in the Lat Lon
> Tools plugin for coordinate capture and zoom-to tools should be "longitude,
> latitude" or "X, Y". Originally, Lat Lon Tools was designed to work with
> on-line maps which are generally "latitude, longitude" order.
> You can always go into the plugin settings and specify which order you want
> and that order will be preserved everytime you launch QGIS. The default
> order is only applicable the first time you install "Lat Lon Tools" or if
> you do a reset to defaults in the Lat Lon Tools settings menu,
> Who prefers Lat Lon Tools to default to "longitude, latitude" or "X, Y"
> when the plugin is first installed or reset to default values?
> Who prefers Lat Lon Tools to default to "latitude, longitude (Google map
> order)" or "Y, X" when the plugin is first installed or reset to default
> values?
> I'm just checking to see if I should make this change or not.
> Thanks,
> Calvin
