[Qgis-user] Vote for Lat Lon Tools Default Coordinate Order -, YX or XY
Priv. Doz. Dr. Maria Shinoto
maria.shinoto at zaw.uni-heidelberg.de
Sat Nov 21 00:52:04 PST 2020
the tool is great, thank you so much -- and I can live with the settings as they are.
Maria
> Am 21.11.2020 um 08:44 schrieb Mike Flannigan <mflan at mflan.com>:
> I too like lat,long, but I can live with anything that is done.
> I'll just set it to lat,long.
> I understand the thinking to change it to X,Y. Many people
> in the field would agree that is better. I'm just not one of them.
> I use this tool constantly. Thank you.
> Mike
> On 11/20/20 2:00 PM, qgis-user-request at lists.osgeo.org wrote:
>> It was suggested to me that the default coordinate order in the Lat Lon
>> Tools plugin for coordinate capture and zoom-to tools should be "longitude,
>> latitude" or "X, Y". Originally, Lat Lon Tools was designed to work with
>> on-line maps which are generally "latitude, longitude" order.
>> You can always go into the plugin settings and specify which order you want
>> and that order will be preserved everytime you launch QGIS. The default
>> order is only applicable the first time you install "Lat Lon Tools" or if
>> you do a reset to defaults in the Lat Lon Tools settings menu,
>> Who prefers Lat Lon Tools to default to "longitude, latitude" or "X, Y"
>> when the plugin is first installed or reset to default values?
>> Who prefers Lat Lon Tools to default to "latitude, longitude (Google map
>> order)" or "Y, X" when the plugin is first installed or reset to default
>> values?
>> I'm just checking to see if I should make this change or not.
>> Thanks,
>> Calvin
> Qgis-user mailing list
