[Qgis-user] Vote for Lat Lon Tools Default Coordinate Order - YX or XY
John Helly
hellyj at ucsd.edu
Fri Nov 20 21:12:32 PST 2020
How about just make it a switchable option? I think GMT battled this
unresolvable subjectivity eons ago.
J.
On 11/20/20 17:25, Brent Wood wrote:
> 1. "lat/lon" is the world wide order for degree based maps (esp in
> the navigation space)
> 2. "Lat Lon is the name of the tool,
> It doesn't make any sense (to me) to have lon/lat as the default order
> for this tool. I know some other GIS tools use lon lat to be
> consistent with northings & eastings which are XY, but with this tool
> being all about lat/lon, I figure that is how it should be.
> One option - if you are really concerned about this. Prompt on first
> use to set the user's preferred default? Make it impossible for the
> user to use the plugin without having first chosen what they want the
> order to be. So it doesn't have a default, just a user selected order.
> Cheers
> My 02c
> > It was suggested to me that the default coordinate order in the Lat
> > Lon Tools plugin for coordinate capture and zoom-to tools should be
> > "longitude, latitude" or "X, Y". Originally, Lat Lon Tools was
> > designed to work with on-line maps which are generally "latitude,
> > longitude" order.
> > You can always go into the plugin settings and specify which order
> > you want and that order will be preserved everytime you launch QGIS.
> > The default order is only applicable the first time you install "Lat
> > Lon Tools" or if you do a reset to defaults in the Lat Lon Tools
> > settings menu,
> > Who prefers Lat Lon Tools to default to "longitude, latitude" or "X,
> > Y" when the plugin is first installed or reset to default values?
> > Who prefers Lat Lon Tools to default to "latitude, longitude (Google
> > map order)" or "Y, X" when the plugin is first installed or reset to
> > default values?
> > I'm just checking to see if I should make this change or not.
> > Thanks,
> > Calvin
> Roxo
> ---------------- Non luctari, ludare -------------------+ WYSIWYG
> Fernando M. Roxo da Motta <petro at roxo.org <mailto:petro at roxo.org>>
> | Editor?
> Except where explicitly stated I speak on my own behalf.| VI !!
> PU5RXO | I see text,
> ------------ Quis custodiet ipsos custodes?-------------+ I get text!
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> <https://urldefense.com/v3/__https://lists.osgeo.org/mailman/listinfo/qgis-user__;!!Mih3wA!SRGN1_yyu0tS9-q2J9cWXOfrYTyPvV4jia9Z8otdkFFzVi9S5V7r_OWqqULT7IE$>
> List info: https://urldefense.com/v3/__https://lists.osgeo.org/mailman/listinfo/qgis-user__;!!Mih3wA!SRGN1_yyu0tS9-q2J9cWXOfrYTyPvV4jia9Z8otdkFFzVi9S5V7r_OWqqULT7IE$
> Unsubscribe: https://urldefense.com/v3/__https://lists.osgeo.org/mailman/listinfo/qgis-user__;!!Mih3wA!SRGN1_yyu0tS9-q2J9cWXOfrYTyPvV4jia9Z8otdkFFzVi9S5V7r_OWqqULT7IE$
John Helly, University of California, San Diego / San Diego Supercomputer Center / Scripps Institution of Oceanography / 760 840 8660 mobile / http://www.sdsc.edu/~hellyj
ORCID ID: orcid.org/0000-0002-3779-0603
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201120/7ec42481/attachment.html>
