[Qgis-user] Toggle Attribute
    L.W.
    eaglelw at gmx.de
    Mon Nov 23 01:29:29 PST 2020
and there are some disadvantages ... first you have to set the layer
active to which the symbol belongs.
there is no "is_" derivat for "get object info" (i-icon with
mouse-pointer), so nothing happened if the feautre attribute-dialog is
shown, the feature is (different) highlighted but not the same way as
"selected" (by the yellow buttons with mouse-pointer).
Am 23.11.2020 um 10:06 schrieb L.W.:
> I tried a little bit with "actions" but - I think you're right - there
> is no onHover.
> anyway, I found a much more comfortable solution for the moment.
> I add the simple term "OR is_selected()" in the if clause for my symbol
> to show the changed color (in my case I draw a line between two points)
> and it worked like a charme.
> But, this is without the option to e.g. display a messagebox or someting
> like that with additional informations of the feature (I know about map
> hints/tips (I do not know the right translation).
> Yes you could made an action for that, but my goal was to show this on
> hover, but click is oooookay.
> For X-Mas my wish in relation to QGIS is a hover event ... on feature on
> map and on symbols. ;-)
> Thanks for helping to everyone.
> PS: Do I have to implement a Plugin to have a dockable window for
> showing infos non modal on per action selected features?
> Am 23.11.2020 um 09:40 schrieb Richard Duivenvoorde:
>> On 11/22/20 8:40 PM, Jésahel Benoist wrote:
>>> The actions are a standard way of acting on graphical objects, so
>>> for me it would be the first thing to try. Did you ?
>>> Le dim. 22 nov. 2020 à 20:01, Bernd Vogelgesang
>>> <bernd.vogelgesang at gmx.de <mailto:bernd.vogelgesang at gmx.de>> a écrit :
>>>      if you would be so kind to explain the "just" part of your
>>> proposal?
>> I think in the User lists it is always good to add a link to some
>> documentation about a QGIS-term. In this case 'actions' kan be a
>> normal word, but (advanced) users maybe (or not) know that it is also
>> something you can use to 'do something in QGIS upon a click on a
>> feature'.
>> Some documentation here:
>> https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/vector_properties.html#actions-menu
>> (or do a search on 'actions' in the QGIS docs site).
>> Tip: go to vector layer properties, 'Actions' tab, and hit 'Create
>> Default Actions' button. You will get all kind of examples.
>> About original post: I do not think we have an Action on hover (plz
>> correct me if I'm wrong), but to run some (PyQGIS) python code is
>> doable.
>> With PyQGIS you can search for features in other layers, and maybe
>> 'select' these on click in the other layer (or change attribute,
>> though I'm not sure how to change it back then... )
>> Acutally this sounds like nice functionality for layers which have
>> relations... I'm not so experienced with relations in layers.
>> If you worked out a way to do this, plz let us know :-)
>> Regards,
>> Richard
> Qgis-user mailing list
