[Qgis-user] Set variables by UI
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Thu Nov 26 02:09:26 PST 2020
Without knowing more about your project than A and B, it is a guessing
game what could be best.
But to me, if I understood correctly, it sounds like you are about to
create a data-redundancy over several layers.
If those attributes are really the same, and stay the same, it would
maybe me wiser to work with relations and/or virtual layers where you
could deliver those common values without having to really store them
individually in each layer.
On 25.11.20 22:43, L.W. wrote:
> That's what I want to use, but how to set the "default value" - no, not
> per propertier and form builder.
> I want to set the DV by input in "UI A" (add feature to layer A) and
> then add new feature to B, and in UI B the DV is set to value from
> form A.
> Am 25.11.2020 um 21:19 schrieb Harrissou:
>> Hi,
>> Something like setting default values for field:
>> https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/vector_properties.html#default-values
>> <https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/vector_properties.html#default-values>
>> Regards,
>> Harrissou
>> Le 25 novembre 2020 20:49:17 GMT+01:00, "L.W." <eaglelw at gmx.de> a
>> écrit :
>> Hello,
>> I have a question again, I know the possibility of the project
>> variables, which can be queried from all layers.
>> I have to insert several points and lines or polygons in
>> different layers.
>> All inserted features have in common that they have certain
>> attributes
>> that are the same for all.
>> It would be nice if I only have to enter these common attributes
>> for the
>> first feature and the values are then automatically inserted as
>> default values for each new feature.
>> One possible way would of course be a link to a shared data
>> table, but I
>> don't necessarily want to go this way for reasons.
>> I know the option of giving a UI a Python script when it is
>> opened (even
>> if I can't Python), but I haven't found anything to execute a script
>> after closing, for example.
>> Obviously logical, you can of course set the variables
>> beforehand, but
>> that would be another step that you have to take beforehand and you
>> cannot get to these variables without a whole series of mouse
>> clicks.
>> Any ideas?
>> Regards
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Envoyé de mon appareil Android avec Courriel K-9 Mail. Veuillez
>> excuser ma brièveté.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201126/d0cf2d63/attachment.html>
