I am playing around with data entry options and wondered if I can use the graphical modeller to add data, e.g. x y coordinates as live input not from a file. Can the data entry be saved as variable which can then be used in the make polygon expression? Cheers Grant -- Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
