[Qgis-user] Does QGIS3 freezes more often than QGIS2 ?
Idan Miara idan at miara.com
Sun Nov 29 04:05:32 PST 2020
Hi David and Kirk,
Thanks for your replies!
I usually drag and drop Cloud Optimized Geotiffs, so I don't think that the
size of the raster is the root of the problem.
I had these freezes also when just setting the focus back on QGIS (alt+tab)
without drag/drop anything.
I've just applied David's suggestion and hid all local drives and network
drives from the Browser (I've never even used those anyway).
Then I dragged and dropped some 30 large COG rasters and so far no more
freezes :)
I'll report again in a few days and open a bug report if that was
indeed the root of the problem.
Idan
On Fri, 27 Nov 2020 at 17:41, David Addy <davesgrandad at gmail.com> wrote:
> I used to get a lot of similar freezes on QGIS 3.
> It was traced to the browser window being full of files that I never would
> use for QGIS.
> So if your browser window within QGIS has a lot of irrelevant stuff, you
> could try clicking on each one and selecting, "Hide from Browser" option.
> This should ensure that QGIS is not wasting time looking through a lot of
> directories that you would never be using with QGIS anyway.
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201129/c77e9a16/attachment.html>
