[Qgis-user] How to add a base map to my project?
Ben Hur Pintor
bnhr.dev at gmail.com
Fri Oct 23 17:11:22 PDT 2020
Hi Maria,
As previously mentioned, you can add basemaps to QGIS by adding them as XYZ
tiles (in the Browser) or using the QuickMapServices plugin (
https://plugins.qgis.org/plugins/quick_map_services/),
You can also check this post for more information and instructions to add
basemaps in QGIS: https://bnhr.xyz/2018/10/07/basemaps-in-qgis.html
I hope these help.
All the best,
Ben Hur
*Ben Hur S. Pintor*
bnhr.xyz
hi at bnhr.xyz
open spatial & data solutions
On Fri, Oct 23, 2020 at 9:45 PM Sebastian Gutwein <bas at rdgland.com> wrote:
> Maria I just realized that you said you were using QGIS 3.6 I am not sure
> if the Open Street Map XYZ tile was preinstalled at that point you may have
> to use the Quick Map Services plugin.
> On Fri, Oct 23, 2020 at 9:40 AM Sebastian Gutwein <bas at rdgland.com> wrote:
>> Maria,
>> There is an Open Street Map included in your installation you can add it
>> through Layer>Add Layer>XYZ Layer>Open Street Map> ADD.
>> Or by double clicking in the browser on the OpenStreetMap in the XYZ
>> Tiles Section.
>> [image: image.png]
>> Additionally there are other basemaps available through the
>> QuickMapServices plugin.
>> Instructions here:
>> https://opengislab.com/blog/2018/4/15/add-basemaps-in-qgis-30
>> Hope that helps.
>> -Bas
>> On Fri, Oct 23, 2020 at 9:22 AM Maria Joao Sacadura <
>> mariajoaosacadura at gmail.com> wrote:
>>> Hi
>>> I have Qgis 3.6 and need to add a base map to a project. How do I do it?
>>> Thanks
>>> *Maria João Sacadura*
>>> *Geologist & MSc in Environmental M**anagement*
>>> *Teacher at Aljezur International School *
>>> *Manager at Biomediterrâneo - **Organic Prod**ucer*
>>> *_______________________________________ *
>>> T: +351 916 485 333
>>> Estrada Municipal Norteo, Caixa Postal nº 1025F
>>> 8650-452 Barão de S. Miguel
>>> Portugal
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201024/5f5644e0/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201024/5f5644e0/attachment.png>
