[Qgis-user] Error al iniciar QGIS 3.10 IndexError: list index out of range
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Thu Oct 29 04:21:46 PDT 2020
Not Spanish speaking, so I'll reply in English...
The error happens if your "qgis.ini" file in:
/%appdata%/\QGIS\QGIS3\profiles\/default\/QGIS contains path references
to non - existing paths under the section [processing]:
(/%appdata%/ : userdata path reference,/default/ : Name of QGIS profile)
Snip from QGIS.ini....
[Processing]
Configuration\OUTPUTS_FOLDER=C:\\Users\\Bo
Victor\\AppData\\Roaming\\QGIS\\QGIS3\\profiles\\default\\processing\\outputs
Configuration\MODELS_FOLDER=C:\\Users\\Bo
Victor\\AppData\\Roaming\\QGIS\\QGIS3\\profiles\\default\\processing\\models
Configuration\SCRIPTS_FOLDERS=C:\\Users\\Bo
Victor\\AppData\\Roaming\\QGIS\\QGIS3\\profiles\\default\\processing\\scripts
End snip...
*If* any of the above path references *doesn't* exist of your pc -
you'll get the error
Remove the offending lines, and the references will be set to default
values (and the error will disappear)
Den 28-10-2020 kl. 13:50 skrev Alejandro Chamizo de Castro:
> Hola,
> cada vez que inicio QGIS se me salta una ventana con el siguiente error:
> Traceback (most recent call last): File
> "C:/PROGRA~1/QGIS3~1.10/apps/qgis-ltr/./python/plugins\processing\script\ScriptAlgorithmProvider.py",
> line 110, in loadAlgorithms folder =
> ScriptUtils.resetScriptFolder(folder) File
> "C:/PROGRA~1/QGIS3~1.10/apps/qgis-ltr/./python/plugins\processing\script\ScriptUtils.py",
> line 114, in resetScriptFolder commonSettingPath =
> os.path.join(paths[appIndex], paths[profileIndex]) IndexError: list
> index out of range
> ¿Sabéis a qué se debe?
> Saludos y gracias
> +34 653681823
> www.gisland.es <http://www.gisland.es>
> Mailtrack
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&>
> Remitente notificado con
> Mailtrack
> 28/10/20 13:50:21
> Qgis-user mailing list
Med venlig hilsen / Kind regards
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201029/9ef74356/attachment.html>
