[Qgis-user] Error al iniciar QGIS 3.10 IndexError: list index out of range
Alejandro Chamizo de Castro
alechamizo at gmail.com
Thu Oct 29 04:43:42 PDT 2020
Thank you very much Victor,
and sorry for write in spanish 🙆
[image: Mailtrack]
<https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&>
Remitente
notificado con
Mailtrack
29/10/20
12:42:17
El jue., 29 oct. 2020 a las 12:21, Bo Victor Thomsen (<
bo.victor.thomsen at gmail.com>) escribió:
> Not Spanish speaking, so I'll reply in English...
> The error happens if your "qgis.ini" file in: *%appdata%*
> \QGIS\QGIS3\profiles\*default\*QGIS contains path references to non -
> existing paths under the section [processing]:
> (*%appdata%* : userdata path reference,* default* : Name of QGIS profile)
> Snip from QGIS.ini....
> [Processing]
> Configuration\OUTPUTS_FOLDER=C:\\Users\\Bo
> Victor\\AppData\\Roaming\\QGIS\\QGIS3\\profiles\\default\\processing\\outputs
> Configuration\MODELS_FOLDER=C:\\Users\\Bo
> Victor\\AppData\\Roaming\\QGIS\\QGIS3\\profiles\\default\\processing\\models
> Configuration\SCRIPTS_FOLDERS=C:\\Users\\Bo
> Victor\\AppData\\Roaming\\QGIS\\QGIS3\\profiles\\default\\processing\\scripts
> End snip...
> *If* any of the above path references *doesn't* exist of your pc - you'll
> get the error
> Remove the offending lines, and the references will be set to default
> values (and the error will disappear)
> Den 28-10-2020 kl. 13:50 skrev Alejandro Chamizo de Castro:
> Hola,
> cada vez que inicio QGIS se me salta una ventana con el siguiente error:
> Traceback (most recent call last):
> File "C:/PROGRA~1/QGIS3~1.10/apps/qgis-ltr/./python/plugins\processing\script\ScriptAlgorithmProvider.py", line 110, in loadAlgorithms
> folder = ScriptUtils.resetScriptFolder(folder)
> File "C:/PROGRA~1/QGIS3~1.10/apps/qgis-ltr/./python/plugins\processing\script\ScriptUtils.py", line 114, in resetScriptFolder
> commonSettingPath = os.path.join(paths[appIndex], paths[profileIndex])
> ¿Sabéis a qué se debe?
> Saludos y gracias
> +34 653681823
> www.gisland.es
> [image: Mailtrack]
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> Remitente
> notificado con
> Mailtrack
> <https://mailtrack.io?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> 28/10/20
> 13:50:21
> Qgis-user mailing listQgis-user at lists.osgeo.org
> Med venlig hilsen / Kind regards
> Bo Victor Thomsen
+34 653681823
www.gisland.es
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201029/4c600b47/attachment.html>
