[Qgis-user] Couldn't load SIP module
Frank Sokolic
sokolic at worldonline.co.za
Thu Oct 29 23:46:04 PDT 2020
Hi Mike,
I can confirm the same problem. I am using the Flatpak version of QGIS
3.14 on Ubuntu 20.10.
Regards, Frank.
On 2020/10/29 22:40, Mike Flannigan wrote:
> I have been using QGIS a lot recently. All of a sudden
> it gives "Couldn't load SIP module", which is a Python
> problem with QGIS that has been around for many years.
> I TimeShifted back about 3 days and the problem is solved
> for now, but I just wanted to get this recorded.
> Here are a few write-ups on the problem, some very recent:
> https://github.com/qgis/QGIS/issues/38310
> https://github.com/qgis/QGIS/issues/30895
> https://gis.stackexchange.com/questions/306595/qgis-3-4-couldnt-load-sip-module-python-support-will-be-disabled-on-windows-10
> The error message I receive is:
> Couldn't load SIP module.
> Python support will be disabled.
> Traceback (most recent call last):
> File "", line 1, in
> File "/app/share/qgis/python/qgis/__init__.py", line 70, in
> from qgis.PyQt import QtCore
> File "/app/share/qgis/python/qgis/PyQt/QtCore.py", line 24, in
> from PyQt5.QtCore import *
> ModuleNotFoundError: No module named 'PyQt5.sip'
> Python version:
> 3.8.5 (default, Nov 10 2011, 15:00:00)
> [GCC 10.2.0]
> QGIS version:
> 3.14.16-Pi 'Pi', a235a149
> Python path:
> ['/app/share/qgis/python',
> '/home/mike/.var/app/org.qgis.qgis/data/QGIS/QGIS3/profiles/default/python',
> '/home/mike/.var/app/org.qgis.qgis/data/QGIS/QGIS3/profiles/default/python/plugins',
> '/app/share/qgis/python/plugins', '/usr/lib/python38.zip',
> '/usr/lib/python3.8', '/usr/lib/python3.8/lib-dynload',
> '/usr/lib/python3.8/site-packages',
> '/app/lib/python3.8/site-packages',
> '/app/lib/python3.8/site-packages/numpy-1.19.2-py3.8-linux-x86_64.egg',
> '/app/lib/python3.8/site-packages/MarkupSafe-1.1.1-py3.8-linux-x86_64.egg']
> Ignoring the error message allows QGIS to start, but then
> you don't have the "Lat Lon Tools" plugin, and a few other things.
> My Python versions appear to be ver 2.7, ver 3.6, ver 3.7.
> Again, I am OK for now, but I hope this issue is resolved soon.
> Mike
> Qgis-user mailing list
