[Qgis-user] Couldn't load SIP module
Antonia Valentin antonia.valentin at gmail.com
Thu Oct 29 23:54:58 PDT 2020
Same here (Linux Mint 20). It seems a Flatpak issue. I am following this
thread:
https://github.com/flathub/org.qgis.qgis/issues/74
I have installed QGIS from conda until this is solved (
https://anaconda.org/conda-forge/qgis).
Best,
Antònia
On Fri, 30 Oct 2020 at 07:46, Frank Sokolic <sokolic at worldonline.co.za>
wrote:
> Hi Mike,
> I can confirm the same problem. I am using the Flatpak version of QGIS
> 3.14 on Ubuntu 20.10.
> Regards, Frank.
> On 2020/10/29 22:40, Mike Flannigan wrote:
> > I have been using QGIS a lot recently.  All of a sudden
> > it gives "Couldn't load SIP module", which is a Python
> > problem with QGIS that has been around for many years.
> > I TimeShifted back about 3 days and the problem is solved
> > for now, but I just wanted to get this recorded.
> > Here are a few write-ups on the problem, some very recent:
> > https://github.com/qgis/QGIS/issues/38310
> > https://github.com/qgis/QGIS/issues/30895
> https://gis.stackexchange.com/questions/306595/qgis-3-4-couldnt-load-sip-module-python-support-will-be-disabled-on-windows-10
> > The error message I receive is:
> > Couldn't load SIP module.
> > Python support will be disabled.
> > Traceback (most recent call last):
> >   File "", line 1, in
> >   File "/app/share/qgis/python/qgis/__init__.py", line 70, in
> >     from qgis.PyQt import QtCore
> >   File "/app/share/qgis/python/qgis/PyQt/QtCore.py", line 24, in
> >     from PyQt5.QtCore import *
> > ModuleNotFoundError: No module named 'PyQt5.sip'
> > Python version:
> > 3.8.5 (default, Nov 10 2011, 15:00:00)
> > [GCC 10.2.0]
> > QGIS version:
> > 3.14.16-Pi 'Pi', a235a149
> > Python path:
> > ['/app/share/qgis/python',
> '/home/mike/.var/app/org.qgis.qgis/data/QGIS/QGIS3/profiles/default/python',
> '/home/mike/.var/app/org.qgis.qgis/data/QGIS/QGIS3/profiles/default/python/plugins',
> > '/app/share/qgis/python/plugins', '/usr/lib/python38.zip',
> > '/usr/lib/python3.8', '/usr/lib/python3.8/lib-dynload',
> > '/usr/lib/python3.8/site-packages',
> > '/app/lib/python3.8/site-packages',
> > '/app/lib/python3.8/site-packages/numpy-1.19.2-py3.8-linux-x86_64.egg',
> '/app/lib/python3.8/site-packages/MarkupSafe-1.1.1-py3.8-linux-x86_64.egg']
> > Ignoring the error message allows QGIS to start, but then
> > you don't have the "Lat Lon Tools" plugin, and a few other things.
> > My Python versions appear to be ver 2.7, ver 3.6, ver 3.7.
> > Again, I am OK for now, but I hope this issue is resolved soon.
> > Mike
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201030/d58606a7/attachment.html>
