[Qgis-user] Installing QGIS 3.14 or 3.16 on Windows: it only runs as administrator
Jorge Gustavo Rocha
jgr at geomaster.pt
Sat Oct 31 04:14:33 PDT 2020
Hi Bo,
Thanks for the feedback.
You are right. I was installing QGIS in a municipality where the
computers are configured by the IT dept. It was a brand new computer,
but I guess it was deployed with some predefined configuration.
I was able to change the QGIS startup settings and it now runs always
with "administrative privileges". But I don't like the solution and I'll
try to start it a --profiles-path path where the user is able to read
and right. I will also talk with the IT, because it is not a QGIS
problem from the feedback I've received. I hope they will contribute to
fix the issue too.
Have a nice weekend!
Jorge
Às 10:27 de 31/10/20, Bo Victor Thomsen escreveu:
> Hi Jorge -
> If it's an so-called "enterprise" setup of the new Windows PC, the IT
> department might have mucked around with all sorts of security and
> userdata setups. QGIS needs to have read/write access to the
> %userdata% path to read and write parameter settings, installing and
> loading plugins and so on.
> You can try:
> * To start QGIS with the--noplugins qualifier. This will stop QGIS
> from loading plugins on startup.
> * To start QGIS with the --profiles-path <some_new_path>
> The--profiles-path qualifier gets QGIS to use another directory
> for profiles storage than the default
> <some_new_path> must point to an existing directory path where
> you're certain you have read/write access to.
> If it actually works with the second suggestion, your IT department
> probably has made the userdata directory inaccessible for QGIS.
> Den 29-10-2020 kl. 18:16 skrev Jorge Gustavo Rocha:
>> Hi,
>> I'm trying to install QGIS using OSGeo4W on a new Windows 10
>> computer. I've tried several options. I started with the "express
>> desktop install".
>> The installation runs smoothly.
>> After installation, the splash screen appear and goes until the
>> message: QGIS is ready! But then, nothing happens. If I run QGIS with
>> Administrator privileges, it works.
>> I've also tried to install with "custom install", just for the
>> current user. But using this option, I get install errors
>> (complaining about a missing gdal301.dll).
>> What can I do (change some permissions?) to have QGIS running with
>> administrator privileges?
>> Disclaimer: I'm not a Windows expert. I probably missed something
>> obviously. I've disabled the antivirus software, just in case.
>> Thanks,
>> Jorge
>> Email Signature
>> Logo <https://www.geomaster.pt>
>> *Geomaster*
>> *Jorge Gustavo Rocha* | Software Engineer
>> *e:*jgr at geomaster.pt | *m:*+351 910 333 888
>> *g:*41.54094,-8.40490 | *v: *510 906 109
>> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Med venlig hilsen / Kind regards
> Bo Victor Thomsen
Email Signature
*Geomaster*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201031/15f9d406/attachment-0001.html>
