[Qgis-user] Installing QGIS 3.14 or 3.16 on Windows: it only runs as administrator
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Sat Oct 31 03:27:10 PDT 2020
Hi Jorge -
If it's an so-called "enterprise" setup of the new Windows PC, the IT
department might have mucked around with all sorts of security and
userdata setups. QGIS needs to have read/write access to the %userdata%
path to read and write parameter settings, installing and loading
plugins and so on.
You can try:
* To start QGIS with the--noplugins qualifier. This will stop QGIS
from loading plugins on startup.
* To start QGIS with the --profiles-path <some_new_path>
The--profiles-path qualifier gets QGIS to use another directory for
profiles storage than the default
<some_new_path> must point to an existing directory path where
you're certain you have read/write access to.
If it actually works with the second suggestion, your IT department
probably has made the userdata directory inaccessible for QGIS.
Den 29-10-2020 kl. 18:16 skrev Jorge Gustavo Rocha:
> Hi,
> I'm trying to install QGIS using OSGeo4W on a new Windows 10 computer.
> I've tried several options. I started with the "express desktop install".
> The installation runs smoothly.
> After installation, the splash screen appear and goes until the
> message: QGIS is ready! But then, nothing happens. If I run QGIS with
> Administrator privileges, it works.
> I've also tried to install with "custom install", just for the current
> user. But using this option, I get install errors (complaining about a
> missing gdal301.dll).
> What can I do (change some permissions?) to have QGIS running with
> administrator privileges?
> Disclaimer: I'm not a Windows expert. I probably missed something
> obviously. I've disabled the antivirus software, just in case.
> Thanks,
> Jorge
> Email Signature
> Logo <https://www.geomaster.pt>
> *Geomaster*
> *Jorge Gustavo Rocha* | Software Engineer
> *e:*jgr at geomaster.pt | *m:*+351 910 333 888
> *g:*41.54094,-8.40490 | *v: *510 906 109
> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
> Qgis-user mailing list
Med venlig hilsen / Kind regards
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201031/d4132545/attachment.html>
