[Qgis-user] Live Mapping with QGIS on Toughbook
Randal Hale rjhale at northrivergeographic.com
Tue Sep 1 05:39:58 PDT 2020
Woot!
I guess that's the one area I am fuzzy on is How QGIS interacts with
GPS's. It seems like it's looking for either a com or USB port. Which
with lets say you have a Bluetooth I'm not sure what you would do (I
have yet to do the Bluetooth -> laptop -> QGIS Dance because I don't
hate my life enough currently). I've connected external GPS (USBs) alot
using GPSgate and supposedly Windows 10 will let you do the same thing
if you configure the settings.....I guess that depends on How the GPS is
hooked into the Laptop.
Anyway - **Official disclaimer** Don't drive down the road looking at
your laptop and wreck.
Randy
On 9/1/20 4:39 AM, Daniel Greene wrote:
> Randal, i think you've just cracked it for me! gpsgate seems to have
> got the gps talking to qgis. many thanks for the help, people.
> On Mon, Aug 31, 2020 at 8:18 PM Randal Hale
> <rjhale at northrivergeographic.com
> <mailto:rjhale at northrivergeographic.com>> wrote:
>     Unfortunately I don't have one to test (but someone I can call)
>     Two things to check:
>     1. Right Click in your QGIS toolbar area and activate your GPS
>     information panel. See if you're connecting to the GPS. Autodetect
>     should tell you something.
>     2. I've used the GPS Gate Splitter Software [1] on Windows 7/10 to
>     connect QGIS to an External GPS. Haven't had the joy to do
>     Bluetooth/internal GPS's but I'd expect Gate Splitter to at least
>     get you connected on an internal....... Although I've heard
>     Windows 10 has something similiar "in the guts" to make that work
>     (no hardware to test that on). Once you install Gate Splitter QGIS
>     should autodetect the GPS.
>     Good Luck - and I think this will work but as I type this I'm
>     starting to think this might be slightly out of date thinking.
>     Randy
>     [1] https://gpsgate.com/products/gpsgate_client
>     On 8/31/20 2:28 AM, Daniel Greene wrote:
>>     Nicolas, the Toughbook definitely has a GPS as i can test the
>>     connection using the GPS software - and i have tried it in
>>     various places.
>>     John, i have copied the project and files on to the desktop with
>>     the same results. i have also tried it without any data to see if
>>     it can pick my position up whilst using only a basemap but still
>>     no luck.
>>     On Fri, Aug 28, 2020 at 10:40 PM Willey, John
>>     <Willey_John at co.sandusky.oh.us
>>     <mailto:Willey_John at co.sandusky.oh.us>> wrote:
>>         Some more information might be needed. Is it possible your
>>         QGIS data resides in a server and not on your local machine?
>>         Perhaps the Toughbook knows where it is, but can't display
>>         the underlying map layers because it can't connect to the
>>         server? That would also explain why it works when you are in
>>         wifi service.
>>         John
>>         John Willey
>>         Executive Director
>>         Sandusky County Regional Planning Commission
>>         2511 Countryside Drive, Suite C
>>         Fremont, OH 43420
>>         (419)334-6227
>>         *From:* Qgis-user [qgis-user-bounces at lists.osgeo.org
>>         <mailto:qgis-user-bounces at lists.osgeo.org>] on behalf of
>>         Nicolas Cadieux [njacadieux.gitlab at gmail.com
>>         <mailto:njacadieux.gitlab at gmail.com>]
>>         *Sent:* Friday, August 28, 2020 10:31 AM
>>         *To:* Daniel Greene
>>         *Cc:* qgis-user at lists.osgeo.org
>>         <mailto:qgis-user at lists.osgeo.org>
>>         *Subject:* Re: [Qgis-user] Live Mapping with QGIS on Toughbook
>>         This message has originated from an *External Source*. Please
>>         use proper judgment and caution when opening attachments,
>>         clicking links, or responding to this email.
>>         Daniel Green from Québec?
>>         I would start by testing in a wide open field.  Is the
>>         problem with the GPS in the laptop or with the connection
>>         with QGIS? If it’s the later, explain what you are doing and
>>         what versions of QGIS using.  If you only get a position with
>>         the wifi, maybe you don’t have an actual GPS chip. Look at
>>         the computer specs.  Some tablettes (iPods also) and rare
>>         phone only use wifi for positioning and do not use an actual
>>         GPS chip.  Make sure you are not in airplane mode with
>>         antenna’s turned off.
>>         Nicolas Cadieux
>>         Ça va bien aller!
>>>         Le 28 août 2020 à 03:49, Daniel Greene
>>>         <dannyjamesgreene at gmail.com
>>>         <mailto:dannyjamesgreene at gmail.com>> a écrit :
>>>         I have been trying to use QGIS for live mapping on my
>>>         Panasonic Toughbook Cf19 MK7 but I cannot get the GPS to
>>>         connect when in the field. The software on the Toughbook
>>>         shows it is picking up satellites so I am confident it isn’t
>>>         the hardware. When I try to connect it occasionally picks up
>>>         my location if I have wi-fi but without it never does.
>>>         Any ideas what might be going wrong?
>>>         _______________________________________________
>>>         Qgis-user mailing list
>>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>         List info:
>>>         https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>         <https://linkprotect.cudasvc.com/url?a=https%3a%2f%2flists.osgeo.org%2fmailman%2flistinfo%2fqgis-user&c=E,1,ARlyMAoKexUsNmidgrWQCJTOZTMFcPY7mFw3sZBO1UxYh5xSRC-Dmup8fK7ljm_ZKiRekYXrflrWCsQvDwG1dmaptx4Jc1A0gyEcYv2Sg5xc28xgwQ,,&typo=1>
>>>         Unsubscribe:
>>>         <https://linkprotect.cudasvc.com/url?a=https%3a%2f%2flists.osgeo.org%2fmailman%2flistinfo%2fqgis-user&c=E,1,GRTbC0ZPyjglWsA0lHVOqYz8C6lM2QdZrifLWsINL6a_ZsNP1UT-S4e5-qjdXHgmh-prJUcCGwUScO4eXVN831SP5FgQpZRz2ra4AuvcO5MO32GNLpdcxBm8&typo=1>
>>     List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>     Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Randal Hale
>     rjhale at northrivergeographic.com  <mailto:rjhale at northrivergeographic.com>
>     (p) 423.653.3611
>     http://www.northrivergeographic.com
Randal Hale
(p) 423.653.3611
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200901/b3946f67/attachment-0001.html>
