[Qgis-user] Migration to Linux
Alexandre Neto
senhor.neto at gmail.com
Fri Sep 4 01:19:32 PDT 2020
Hello,
QGIS from Ubuntu repositories are generally very outdated. For that reason,
we always suggest you to add a QGIS project PPA repository and install a
more recent version.
Here you can find instructions on how to add the QGIS PPA repository in
ubuntu based machines and install QGIS 3.14:
https://www.qgis.org/en/site/forusers/alldownloads.html#quickstart
If you want to install QGIS 3.10 LTR, which I suggest you do, you will need
to read about the different repositories bellow. Basically, you need to
replace the URL in the quickstart instructions by this one:
https://qgis.org/ubuntu-ltr
Best regards,
Alexandre Neto
QGIS Support
www.qcooperative.net
A quinta, 3/09/2020, 13:47, Jo <winfixit at gmail.com> escreveu:
> I'm also using QGIS on Linux Mint.
> On Thu, Sep 3, 2020 at 2:33 PM Mike Flannigan <mikeflan at att.net> wrote:
>> I moved from Win to Linux about a year ago. I tried
>> Ubuntu first. Due to difficulties installing QGIS
>> I moved to Mint, which worked immediately from the
>> software manager with an older version if I remember
>> correcly. I worked quite a while on installing QGIS
>> on Ubuntu because I really wanted to use Ubuntu.
>> You can go back to 10/19/2019 in the list archives, or
>> you can see the discussion here:
>> http://www.mflan.com/temp/re_[qgis-user]_problems_with_development_version.eml
>> Mike
>> On 9/3/20 2:22 AM, qgis-user-request at lists.osgeo.org wrote:
>> > Hi,
>> > Why I will probably go Linux on my Windows 7 laptop. The desktop will
>> probably need to stay on Windows because of the other stuff. I don’t want
>> a dual boot.
>> > What disto would you consider that makes it easy for inexperienced
>> Linux users. Seems like every time I installed Ubuntu, I ended up breaking
>> it beyond repair...
>> > Any GIS friendly distros to recommend?
>> > Nicolas Cadieux
>> > Ça va bien aller!
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200904/c3cb51c6/attachment.html>
