[Qgis-user] Migration to Linux
Hernán De Angelis
dhdeangelis at comhem.se
Fri Sep 4 01:28:17 PDT 2020
Although not mentioned very often, openSUSE is also a user friendly,
stable and high quality distro. I am a user since 2005 and have seldom
had any problem in all those years. As for QGIS and other geotools there
is the Application:Geo repository that is well updated and maintained.
My choice however is to compile QGIS from source every once in a while.
It is not so difficult as it sounds but perhaps not everyone's cup of tea.
/H.
On 2020-09-04 10:19, Alexandre Neto wrote:
> Hello,
> QGIS from Ubuntu repositories are generally very outdated. For that
> reason, we always suggest you to add a QGIS project PPA repository and
> install a more recent version.
> Here you can find instructions on how to add the QGIS PPA repository
> in ubuntu based machines and install QGIS 3.14:
> https://www.qgis.org/en/site/forusers/alldownloads.html#quickstart
> If you want to install QGIS 3.10 LTR, which I suggest you do, you will
> need to read about the different repositories bellow. Basically, you
> need to replace the URL in the quickstart instructions by this one:
> https://qgis.org/ubuntu-ltr
> Best regards,
> Alexandre Neto
> QGIS Support
> www.qcooperative.net <http://www.qcooperative.net>
> A quinta, 3/09/2020, 13:47, Jo <winfixit at gmail.com
> <mailto:winfixit at gmail.com>> escreveu:
> I'm also using QGIS on Linux Mint.
> On Thu, Sep 3, 2020 at 2:33 PM Mike Flannigan <mikeflan at att.net
> <mailto:mikeflan at att.net>> wrote:
> I moved from Win to Linux about a year ago. I tried
> Ubuntu first. Due to difficulties installing QGIS
> I moved to Mint, which worked immediately from the
> software manager with an older version if I remember
> correcly. I worked quite a while on installing QGIS
> on Ubuntu because I really wanted to use Ubuntu.
> You can go back to 10/19/2019 in the list archives, or
> you can see the discussion here:
> http://www.mflan.com/temp/re_[qgis-user]_problems_with_development_version.eml
> <http://www.mflan.com/temp/re_%5Bqgis-user%5D_problems_with_development_version.eml>
> Mike
> On 9/3/20 2:22 AM, qgis-user-request at lists.osgeo.org
> <mailto:qgis-user-request at lists.osgeo.org> wrote:
> > Hi,
> > Why I will probably go Linux on my Windows 7 laptop. The
> desktop will probably need to stay on Windows because of the
> other stuff. I don’t want a dual boot.
> > What disto would you consider that makes it easy for
> inexperienced Linux users. Seems like every time I installed
> Ubuntu, I ended up breaking it beyond repair...
> > Any GIS friendly distros to recommend?
> > Nicolas Cadieux
> > Ça va bien aller!
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200904/75435f08/attachment.html>
