[Qgis-user] GPX data in QGIS.
Charles Dixon-Paver
charles at kartoza.com
Thu Sep 10 12:07:05 PDT 2020
I'm not familiar with the app you refer to, but I think the data you're
after is the attribute information (right click a layer and open attribute
table).
Routes are an ordered combination of points, which indicate the position
and direction, whilst tracks are a log of the receiver position over time.
In practice, if you were just tracking a hike through the forest, it's
probably not of great importance, however if you were doing field capture
of high fidelity data (e.g. a road network, with specific start and end
positions in a street, with the direction indicating traffic flow etc), you
would probably find the distinction has significantly more value. A more
experienced expert can correct me if I've caused any confusion, but that's
my understanding of it anyway.
Regards
On Thu, 10 Sep 2020 at 20:12, J. M <jimimckay at gmail.com> wrote:
> Hi there,
> I can successfully import .gpx files into QGIS, and they are visible and
> can be clustered in new groups (waypoints, tracks and routes appear as
> independent layers). The problem I'm having is that I can't seem to find
> any way to access the data about the routes (distance, time, etc) which is
> clearly visible in the app I used to create the tracks (the Spanish
> Geographical Institute app, which I understand is heavily based on Orux
> Maps). Does anyone have any ideas how to access this data (it's not in the
> Properties tab)?
> Also, what's the difference between a route and a track for QGIS? Is it
> just the direction the track was completed in?
> Many thanks,
> Jimi.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200910/dcadb93e/attachment.html>
