[Qgis-user] Do map tips not work for anyone?
Alexandre Neto senhor.neto at gmail.com
Thu Sep 10 16:49:53 PDT 2020
Hi Farhan,
I confirm that Map tips are not working for me either while using qgis from
conda installation. It is probably related to this long-standing issue:
https://github.com/conda-forge/qgis-feedstock/issues/68
This affects many plugins, like DataPlotly and Resource Sharing, but also
core functionality, like 3D views. For that reason, conda installation may
be good to set up a reproducible PyQGIS environment or to run processing
modules, but may not be enough for everyday usage using the GUI because of
this limitations
Best regards,
Alexandre Neto
On Fri, Sep 11, 2020 at 12:15 AM Rizwi, Farhan (O&A, Hobart)
<Farhan.Rizwi at csiro.au> wrote:
> Thanks Fernando.
> Good idea! But no change 🙁
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of
> Fernando M. Roxo da Motta <petro at roxo.org>
> *Sent:* Friday, 11 September 2020 2:35 AM
> *To:* qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
> *Subject:* Re: [Qgis-user] Do map tips not work for anyone?
> On Thu, 10 Sep 2020 05:53:14 +0000, "Rizwi, Farhan (O&A, Hobart)"
>   Hi Farhan,
>   I don't have the answer you seek but just a suggestion.  I vaguely
> recall that some time ago I installed a plugin that (for some unknown
> reason) changed the cursor shape.   Anyway, try to start Qgis without
> starting the plugins (--noplugins I think).
>   If this solves your problem and cursor changes back to what you think
> is normal, start activating the plugins one by one (or use a binary
> search).
>   If the problem is not solved disabling the plugins, then it is far
> beyond my capacities.  😳😳
>   Slds.
> > Hi,
> > I posted the following bug report but was immediately closed
> > as conda installations are not supported by QGIS. There is
> > no issue with direct installations of QGIS but I've been
> > consistently had this problem right up to the current
> > 3.14,15. The link below has a screenshot, whereby the "hand"
> > icon is never displayed, only ever crosshairs. The zoom
> > magnifying glass works find but clicking on the hand icon
> > does not turn the cursor into a hand and map tips are never
> > displayed even after enabling them
> > https://github.com/qgis/QGIS/issues/36957
> > Anyone seen this before?
> > Thanks for any tips!
> > Cheers,
> > -Farhan
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>   Roxo
> ---------------- Non luctari, ludare -------------------+ WYSIWYG
> Fernando M. Roxo da Motta <petro at roxo.org>              | Editor?
> Except where explicitly stated I speak on my own behalf.|  VI !!
>                 PU5RXO                                  | I see text,
> ------------ Quis custodiet ipsos custodes?-------------+ I get text!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200911/5bef8652/attachment.html>
