[Qgis-user] Do map tips not work for anyone?
Rizwi, Farhan (O&A, Hobart)
Farhan.Rizwi at csiro.au
Thu Sep 10 19:18:04 PDT 2020
Thanks Alexandre, good to hear it's not just me!
Right okay, thanks for link, makes sense. So far the map tips are the only thing that I've noticed not working for me but it's possible other things are broken too and could be all related.
Cheers,
-Farhan
Sent: Friday, 11 September 2020 9:49 AM
To: Rizwi, Farhan (O&A, Hobart) <Farhan.Rizwi at csiro.au>
Cc: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>; petro at roxo.org <petro at roxo.org>
Subject: Re: [Qgis-user] Do map tips not work for anyone?
Hi Farhan,
I confirm that Map tips are not working for me either while using qgis from conda installation. It is probably related to this long-standing issue:
https://github.com/conda-forge/qgis-feedstock/issues/68
This affects many plugins, like DataPlotly and Resource Sharing, but also core functionality, like 3D views. For that reason, conda installation may be good to set up a reproducible PyQGIS environment or to run processing modules, but may not be enough for everyday usage using the GUI because of this limitations
Best regards,
Alexandre Neto
On Fri, Sep 11, 2020 at 12:15 AM Rizwi, Farhan (O&A, Hobart) <Farhan.Rizwi at csiro.au> wrote:
Thanks Fernando.
Good idea! But no change 🙁
From: Qgis-user <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> on behalf of Fernando M. Roxo da Motta <petro at roxo.org<mailto:petro at roxo.org>>
Sent: Friday, 11 September 2020 2:35 AM
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org> <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>
On Thu, 10 Sep 2020 05:53:14 +0000, "Rizwi, Farhan (O&A, Hobart)"
Hi Farhan,
I don't have the answer you seek but just a suggestion. I vaguely
recall that some time ago I installed a plugin that (for some unknown
reason) changed the cursor shape. Anyway, try to start Qgis without
starting the plugins (--noplugins I think).
If this solves your problem and cursor changes back to what you think
is normal, start activating the plugins one by one (or use a binary
search).
If the problem is not solved disabling the plugins, then it is far
beyond my capacities. 😳😳
Slds.
> Hi,
> I posted the following bug report but was immediately closed
> as conda installations are not supported by QGIS. There is
> no issue with direct installations of QGIS but I've been
> consistently had this problem right up to the current
> 3.14,15. The link below has a screenshot, whereby the "hand"
> icon is never displayed, only ever crosshairs. The zoom
> magnifying glass works find but clicking on the hand icon
> does not turn the cursor into a hand and map tips are never
> displayed even after enabling them
> https://github.com/qgis/QGIS/issues/36957
> Anyone seen this before?
> Thanks for any tips!
> Cheers,
> -Farhan
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org<mailto:petro at roxo.org>> | Editor?
Except where explicitly stated I speak on my own behalf.| VI !!
PU5RXO | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200911/2c7c0674/attachment-0001.html>
