[Qgis-user] How do people unit test plugin code?
Alessandro Pasotti
apasotti at gmail.com
Thu Sep 24 00:45:04 PDT 2020
On Thu, Sep 24, 2020 at 9:36 AM Ian Turton <ijturton at gmail.com> wrote:
> I was toying with refactoring my plugin code the other day, but I thought I would add some unit tests using pytest before I started to make sure I didn't break anything. But when I try something like:
> def test_convertGridRef():
> QgsExpression.registerFunction(convertGridRef)
> e = QgsExpression('convertGridRef("SE2720")')
> assert e.evaluate(None) == 'POINT (427000 420000)'
> e.evaluate returns None - when it should either return a point or an exception
> Does anyone have some good plugin unit test examples I can take a look at?
Hi Jan,
There are many possible approaches to plugin testing, one of the most
interesting IMO is to use the testing docker which allows you to run
the tests inside a real QGIS instance and not a mocked one.
You can find examples of this setup in
https://github.com/inasafe/inasafe/blob/develop/.travis.yml and there
is some documentation in
https://github.com/qgis/QGIS/tree/master/.docker#running-unit-tests-inside-qgis
Hope this helps.
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
