[Qgis-user] GDA94 and WGS84 transformations
Stephane Goldstein
s.n.g at gmx.com
Wed Sep 30 20:23:12 PDT 2020
Hi.
I'm having trouble understanding how QGIS handles the conversion from the
Australian datum to WGS84 in the UTM grid.
GDA94 (EPSG:4283) / MGA94 Zone 5X (EPSG:2835x)
WGS84 (EPSG:4326) / UTM South (EPSG:3265x)
As far as I know the only difference between those two is the ellipsoid
flattening parameters:
GDA94: 298.257222101
WGS84: 298.257223563
When converting from WGS84 <--> GDA94 in degrees, I get exact same
coordinates
GDA94 115.82318346600005 -31.948283257999947
WGS84 115.82318346600005 -31.948283257999947
This is expected, since the CRSs transformation assumes the two ellipsoids
are identical:
EPSG:1150 GDA94 to WGS 84 (1)
Approximation at the +/- 3m level using inappropriate assumption that GDA94
is equivalent to WGS 84. Accuracy changed from 1m to 3m due to tectonic
plate motion over more than 15 years.
+proj=noop
However when going from degrees to UTM or MGA, I get different values:
To
MGA50 388777.573657*112836372* 6464692.233*647795394063*
UTM50 388777.573657*624074258* 6464692.233
*548169955611*
To
MGA50 388777.573657112836372 6464692.233647795394063
UTM50 388777.573657624074258 6464692.233548169955611
To
I don't know why UTM and MGA coordinates differ, since the transformation
used still assumes WGS and GDA have the same ellipsoid:
INVERSE(EPSG):16150, INVERSE(EPSG):1150
Inverse of UTM zone 50S + Inverse of GDA94 to WGS 84 (1)
+proj=pipeline +step +inv +proj=utm +zone=50 +south +ellps=WGS84 +step
+proj=unitconvert +xy_in=rad +xy_out=deg
I have been considering those CRSs identical and using them interchangeably
till now, but realized it is not the case after getting errors in my
process.
Any clarification is appreciated.
Cheers.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201001/d3d242bd/attachment.html>
