[Qgis-user] overlay_nearest expression: filter condition
daniel_u
daur at access.uzh.ch
Tue Apr 6 07:53:39 PDT 2021
I'm using quite often the new and extremely useful ovelay-expressions
introduced in QGIS 3.16. I'm wondering about how the filter-argument of
overlay_nearest works. It seems that the filter works only on the layer that
is referenced. I am not able to set a condition in a way to evaluate
features from any other layer than the one defined in the first argument.
So my question is: Is this a missing feature? Is it a bug? Or do I miss
something and it is possible? In this case: what is the syntax used for
that?
To make the idea a bit less abstract (see also here for details:
https://gis.stackexchange.com/q/391120/88814):
I have layer1 and layer2 and I apply an overlay_nearest expression on layer1
to get features of layer 2. That works fine. The expression returns for each
feature of layer1 an array of features of layer2, ordered according to the
distance from the feature on layer1. The optional filter argument allows it
to limit the results based on a defined condition. As long as i use fields
from layer2, this works fine.
However, I want to set a filter condition that compares attributes from both
layers, but I am not able to find a valid syntax. The following pseudo-code,
used for geometry generator symbol layer on layer1, should return the
geometry of all features on layer 2, but only where the condition is met
that id1 (feature id of layer 1) is not equal to the feature id of layer 2
(id2):
overlay_nearest (
'layer2',
$geometry,
filter:= id 1 <> id2
It is clear that this code here can not work as QGIS looks in layer2
(defined in the first argument) for the two fieldnames. But even when
explicitely refering to the layers, it does not work - e.g. using this
expression here as filter condition:
attribute (
get_feature_by_id (
'layer1',
$id
'id1'
attribute (
get_feature_by_id (
'layer2',
$id
'id2'
So any idea if this is directly possible using the filter argument of
overlay_nearest?
Daniel
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
