[Qgis-user] Shapefiles
Andreas Neumann
a.neumann at carto.net
Thu Apr 8 05:13:55 PDT 2021
Hi Paddy,
The .shp file contains the geometries. If your data contains no
geometries, then you might be fine with the .dbf file that contains the
no-geometry part of your data (attribute columns). No - it is not
possible to recreate the .shp file if it is missing.
Andreas
On 2021-04-08 14:07, Pat Brown wrote:
> Hi,
> So, just to confirm what I already suspect? If you have the .shx and
> .dbf files but the .shp file is missing then you might as well get rid
> of them? It is not possible to recreate the .shp file?
> Thanks,
> Paddy
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210408/83c0c21b/attachment.html>
