[Qgis-user] Shapefiles
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Fri Apr  9 12:31:59 PDT 2021
I agree,
Unless someone actually when true the trouble of story the geometry in the database.  Look for x an y columns for point or a geometry column or a WKT format.  If so, you could recreate the geometry from that information.  But chances are you have no such data in the databas.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 8 avr. 2021 à 08:14, Andreas Neumann <a.neumann at carto.net> a écrit :
> Hi Paddy,
> The .shp file contains the geometries. If your data contains no geometries, then you might be fine with the .dbf file that contains the no-geometry part of your data (attribute columns). No - it is not possible to recreate the .shp file if it is missing.
> Andreas
>> On 2021-04-08 14:07, Pat Brown wrote:
>> Hi,
>>    So, just to confirm what I already suspect? If you have the .shx and .dbf files but the .shp file is missing then you might as well get rid of them? It is not possible to recreate the .shp file?
>> Thanks,
>> Paddy
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210409/fb509e64/attachment.html>
