[Qgis-user] New Map View / New 3D Map View not opening
Nicole Stoffels n.stoffels at googlemail.com
Fri Apr 9 05:40:57 PDT 2021
Hi Charles,
thank you! That was the problem. With a new userprofile my new map opened!
Best wishes
Nicole
Am Fr., 9. Apr. 2021 um 14:37 Uhr schrieb Charles Dixon-Paver <
charles at kartoza.com>:
> It may be a configuration problem. Can you try to open a 3D view with a
> new QGIS userprofile?
> On Fri, 9 Apr 2021 at 14:32, Nicole Stoffels <n.stoffels at googlemail.com>
> wrote:
>> Hi Saber,
>> thank you for your fast reply and the tutorial!
>> Unfortunately I never get to that point. Some colleagues still use QGIS
>> 3.14 and there the new window with the map appears, when they click on View
>> > New 3D Map View. However since my upgrade to QGIS 3.16 no new window
>> opens. In fact there is no reaction at all, when I click View > New 3D Map
>> View.
>> Best regards
>> Nicole
>> Am Fr., 9. Apr. 2021 um 12:26 Uhr schrieb Saber Razmjooei <
>> saber.razmjooei at lutraconsulting.co.uk>:
>>> Hi Nicole,
>>> You may try this tutorial:
>>> https://www.lutraconsulting.co.uk/blog/2018/03/01/working-with-qgis-3d-part-1/
>>> The interface has slightly changed/improved, but in general it gives you
>>> an idea how to view your terrain rasters in 3D.
>>> Kind regards
>>> Saber
>>> On Fri, 9 Apr 2021 at 09:10, Nicole Stoffels <n.stoffels at googlemail.com>
>>> wrote:
>>>> Dear all,
>>>> I would like to create a 3D map view of DEM data with QGIS 3.16.5 on a
>>>> Windows 10. I used this dataset for a test:
>>>> https://www.lgln.niedersachsen.de/download/121709/ATKIS-DGM_DGM1_DGM5_DGM10_DGM25_DGM50_aus_dem_aktuellen_Laserdatenbestand_.zip
>>>> I load the data as a raster which works just fine (EPSG: 25832). I can
>>>> produce hillshades and everything. But when I go to View -> New 3D Map View
>>>> absolutely nothing happens. No new window opens. I don't even get an error
>>>> message. The same happens with New Map View.
>>>> At gis.stackexchange I can't find entries with similar problems.
>>>> Does anyone have any ideas, solutions, the same problems?
>>>> Thank you very much in advance!
>>>> Best regards
>>>> Nicole
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Saber Razmjooei
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210409/c455105a/attachment.html>
