[Qgis-user] New Map View / New 3D Map View not opening
Charles Dixon-Paver
charles at kartoza.com
Fri Apr 9 05:37:24 PDT 2021
It may be a configuration problem. Can you try to open a 3D view with a new
QGIS userprofile?
On Fri, 9 Apr 2021 at 14:32, Nicole Stoffels <n.stoffels at googlemail.com>
wrote:
> Hi Saber,
> thank you for your fast reply and the tutorial!
> Unfortunately I never get to that point. Some colleagues still use QGIS
> 3.14 and there the new window with the map appears, when they click on View
> > New 3D Map View. However since my upgrade to QGIS 3.16 no new window
> opens. In fact there is no reaction at all, when I click View > New 3D Map
> View.
> Best regards
> Nicole
> Am Fr., 9. Apr. 2021 um 12:26 Uhr schrieb Saber Razmjooei <
> saber.razmjooei at lutraconsulting.co.uk>:
>> Hi Nicole,
>> You may try this tutorial:
>> https://www.lutraconsulting.co.uk/blog/2018/03/01/working-with-qgis-3d-part-1/
>> The interface has slightly changed/improved, but in general it gives you
>> an idea how to view your terrain rasters in 3D.
>> Kind regards
>> Saber
>> On Fri, 9 Apr 2021 at 09:10, Nicole Stoffels <n.stoffels at googlemail.com>
>> wrote:
>>> Dear all,
>>> I would like to create a 3D map view of DEM data with QGIS 3.16.5 on a
>>> Windows 10. I used this dataset for a test:
>>> https://www.lgln.niedersachsen.de/download/121709/ATKIS-DGM_DGM1_DGM5_DGM10_DGM25_DGM50_aus_dem_aktuellen_Laserdatenbestand_.zip
>>> I load the data as a raster which works just fine (EPSG: 25832). I can
>>> produce hillshades and everything. But when I go to View -> New 3D Map View
>>> absolutely nothing happens. No new window opens. I don't even get an error
>>> message. The same happens with New Map View.
>>> At gis.stackexchange I can't find entries with similar problems.
>>> Does anyone have any ideas, solutions, the same problems?
>>> Thank you very much in advance!
>>> Best regards
>>> Nicole
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Saber Razmjooei
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210409/8c96cd5e/attachment.html>
