[Qgis-user] New Map View / New 3D Map View not opening
Nicole Stoffels
n.stoffels at googlemail.com
Fri Apr 9 05:32:15 PDT 2021
Hi Saber,
thank you for your fast reply and the tutorial!
Unfortunately I never get to that point. Some colleagues still use QGIS
3.14 and there the new window with the map appears, when they click on View
> New 3D Map View. However since my upgrade to QGIS 3.16 no new window
opens. In fact there is no reaction at all, when I click View > New 3D Map
View.
Best regards
Nicole
Am Fr., 9. Apr. 2021 um 12:26 Uhr schrieb Saber Razmjooei <
saber.razmjooei at lutraconsulting.co.uk>:
> Hi Nicole,
> You may try this tutorial:
> https://www.lutraconsulting.co.uk/blog/2018/03/01/working-with-qgis-3d-part-1/
> The interface has slightly changed/improved, but in general it gives you
> an idea how to view your terrain rasters in 3D.
> Kind regards
> Saber
> On Fri, 9 Apr 2021 at 09:10, Nicole Stoffels <n.stoffels at googlemail.com>
> wrote:
>> Dear all,
>> I would like to create a 3D map view of DEM data with QGIS 3.16.5 on a
>> Windows 10. I used this dataset for a test:
>> https://www.lgln.niedersachsen.de/download/121709/ATKIS-DGM_DGM1_DGM5_DGM10_DGM25_DGM50_aus_dem_aktuellen_Laserdatenbestand_.zip
>> I load the data as a raster which works just fine (EPSG: 25832). I can
>> produce hillshades and everything. But when I go to View -> New 3D Map View
>> absolutely nothing happens. No new window opens. I don't even get an error
>> message. The same happens with New Map View.
>> At gis.stackexchange I can't find entries with similar problems.
>> Does anyone have any ideas, solutions, the same problems?
>> Thank you very much in advance!
>> Best regards
>> Nicole
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Saber Razmjooei
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210409/fdaaba22/attachment.html>
