[Qgis-user] New Map View / New 3D Map View not opening
    Saber Razmjooei
    saber.razmjooei at lutraconsulting.co.uk
    Fri Apr  9 03:25:51 PDT 2021
Hi Nicole,
You may try this tutorial:
https://www.lutraconsulting.co.uk/blog/2018/03/01/working-with-qgis-3d-part-1/
The interface has slightly changed/improved, but in general it gives you an
idea how to view your terrain rasters in 3D.
Kind regards
Saber
On Fri, 9 Apr 2021 at 09:10, Nicole Stoffels <n.stoffels at googlemail.com>
wrote:
> Dear all,
> I would like to create a 3D map view of DEM data with QGIS 3.16.5 on a
> Windows 10. I used this dataset for a test:
> https://www.lgln.niedersachsen.de/download/121709/ATKIS-DGM_DGM1_DGM5_DGM10_DGM25_DGM50_aus_dem_aktuellen_Laserdatenbestand_.zip
> I load the data as a raster which works just fine (EPSG: 25832). I can
> produce hillshades and everything. But when I go to View -> New 3D Map View
> absolutely nothing happens. No new window opens. I don't even get an error
> message. The same happens with New Map View.
> At gis.stackexchange I can't find entries with similar problems.
> Does anyone have any ideas, solutions, the same problems?
> Thank you very much in advance!
> Best regards
> Nicole
> Qgis-user mailing list
Saber Razmjooei
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210409/b6c1a13b/attachment.html>
