[Qgis-user] Editing attribute table
    Pat Brown
    mistyhaven at gmail.com
    Sun Apr 11 14:55:09 PDT 2021
As a follow-on to my earlier query, after much digging if found some files
in this shapefile folder that might answer my question. There are three
files with exactly the same data as the attribute table. One is a csv file,
one an xls file and one an mdb file. I figured that this is the derived
data that the attribute table is reading from. How can I tell which one it
is? Can I edit this file while the layer is open or should I first remove
the layer before editing?
Thank you,
Paddy
On Sun, Apr 11, 2021, 19:28 Pat Brown <mistyhaven at gmail.com> wrote:
> Hi
>     I am having a problem with changing co-ordinate in my attribute table.
> I am using QGIS 3.18 on WIN 97,so far without any issues.
>    It is a point layer with towns and their co-ordinates. Three of these
> data points had empty co-ordinate records and they displayed way out of
> position. This was already a mystery as I couldn't figure out how it could
> display without these. I then filled in the correct co-ordinates but the
> points are still displaying incorrectly.
>    Then I noticed that on the "identify feature" panel there is a subunit
> called (Derived) and it says (clicked coordinate X and Y). How do I edit
> this or get rid of this?
> Many thanks,
> Paddy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210411/aed7b215/attachment.html>
