[Qgis-user] Google map images better on iDevice that in Qgis?
Jeff Sonnentag jsonnentag at llenviroinc.com
Thu Apr 15 17:29:44 PDT 2021
Are you using the XYZ Tiles for Google Earth image loading?
If so, that is also what I have been using and you can set the minimum and maximum zoom level.  In order to get exported maps to look OK I set the minimum to 18 and maximum to 19.  Based on what I gather from reading other people's suggestions I think adjusting the dpi for the output image changes what tiles are loaded in.  But you can force it to use just one zoom level of tiles.  I export everything at 300 dpi to use just to make sure things look OK for color printing and PDFs exported from report files.
This is the URL I have entered for Google Satellite as an XYZ Connection:
http://mt0.google.com/vt/lyrs=s&hl=en&x={x}&y={y}&z={z}
Just looking at the other settings now I see there are 2 options for the Tile Resolution: 256x256/96 dpi and 512x512/192 dpi  (so I might play with those sometime to see what changes)
I still always have to go to Google Earth to compare and see exactly what month and year the tiles are coming from.
-----Original Message-----
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Steve Research
Sent: Thursday, April 15, 2021 9:56 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Google map images better on iDevice that in Qgis?
I am trying to use Google ‘satellite view’ to give me a photo image in my maps. The resolution in Qgis (or a PC browser) is much less clear than in the g Google Maps app on an iPhone. Does anyone know how to get the same hi res imaging as I see on my iPad?
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
