[Qgis-user] Google map images better on iDevice that in Qgis?
Steve Research stevesteveresearch at gmail.com
Fri Apr 16 04:30:16 PDT 2021
I am using Web>OpenLayers Plugin>Google Maps to deliver the data and can’t see anything there so set these details.
I will follow these links to see what that looks like.
> On 16 Apr 2021, at 01:29, Jeff Sonnentag <jsonnentag at llenviroinc.com> wrote:
> Are you using the XYZ Tiles for Google Earth image loading?
> If so, that is also what I have been using and you can set the minimum and maximum zoom level.  In order to get exported maps to look OK I set the minimum to 18 and maximum to 19.  Based on what I gather from reading other people's suggestions I think adjusting the dpi for the output image changes what tiles are loaded in.  But you can force it to use just one zoom level of tiles.  I export everything at 300 dpi to use just to make sure things look OK for color printing and PDFs exported from report files.
> This is the URL I have entered for Google Satellite as an XYZ Connection:
> http://mt0.google.com/vt/lyrs=s&hl=en&x={x}&y={y}&z={z}
> Just looking at the other settings now I see there are 2 options for the Tile Resolution: 256x256/96 dpi and 512x512/192 dpi  (so I might play with those sometime to see what changes)
> I still always have to go to Google Earth to compare and see exactly what month and year the tiles are coming from.
> -----Original Message-----
> From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Steve Research
> Sent: Thursday, April 15, 2021 9:56 AM
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Google map images better on iDevice that in Qgis?
> Hi,
> I am trying to use Google ‘satellite view’ to give me a photo image in my maps. The resolution in Qgis (or a PC browser) is much less clear than in the g Google Maps app on an iPhone. Does anyone know how to get the same hi res imaging as I see on my iPad?
> Qgis-user mailing list
