[Qgis-user] Google map images better on iDevice that in Qgis?
tijan49 at yahoo.fr
tijan49 at yahoo.fr
Fri Apr 16 04:53:21 PDT 2021
You'd better try the QuickMapServices plugin, wich result better than
Open Layers plugin ...
Jean
Le 16/04/2021 à 13:30, Steve Research a écrit :
> I am using Web>OpenLayers Plugin>Google Maps to deliver the data and can’t see anything there so set these details.
> I will follow these links to see what that looks like.
>> On 16 Apr 2021, at 01:29, Jeff Sonnentag <jsonnentag at llenviroinc.com> wrote:
>> Are you using the XYZ Tiles for Google Earth image loading?
>> If so, that is also what I have been using and you can set the minimum
and maximum zoom level. In order to get exported maps to look OK I set the minimum to 18 and maximum to 19. Based on what I gather from reading other people's suggestions I think adjusting the dpi for the output image
changes what tiles are loaded in. But you can force it to use just one zoom level of tiles. I export everything at 300 dpi to use just to make sure things look OK for color printing and PDFs exported from report files.
>> This is the URL I have entered for Google Satellite as an XYZ Connection:
>> http://mt0.google.com/vt/lyrs=s&hl=en&x={x}&y={y}&z={z}
>> Just looking at the other settings now I see there are 2 options for the Tile Resolution: 256x256/96 dpi and 512x512/192 dpi (so I might play with those sometime to see what changes)
>> I still always have to go to Google Earth to compare and see exactly what month and year the tiles are coming from.
>> -----Original Message-----
>> From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Steve
Research
>> Sent: Thursday, April 15, 2021 9:56 AM
>> To: qgis-user at lists.osgeo.org
>> Subject: [Qgis-user] Google map images better on iDevice that in Qgis?
>> Hi,
>> I am trying to use Google ‘satellite view’ to give me a photo image in my maps. The resolution in Qgis (or a PC browser) is much less clear than in the g Google Maps app on an iPhone. Does anyone know
how to get the same hi res imaging as I see on my iPad?
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
