[Qgis-user] Geo Referencing - The image does not fall in the right place
    Jeff Sonnentag
    jsonnentag at llenviroinc.com
    Tue Apr 20 09:52:42 PDT 2021
If you are using QGIS 3.16 then this reference is supposed to be the latest instructions:
https://docs.qgis.org/3.16/en/docs/user_manual/working_with_raster/georeferencer.html
I have had a similar problem in the past but it generally works if you set the Georeferencing SRS in the Georeferencer Transformation Settings to the map’s current CRS (shown in the bottom left corner of the map).
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of krishna Ayyala
Sent: Tuesday, April 20, 2021 8:16 AM
To: qgis-user <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Geo Referencing - The image does not fall in the right place
Hello,
I have a jpeg image that I georeferenced using the steps mentioned in the following link. At the end, the image does not fall in the right place. As shown in step13, a modified image is created and saved in the folder. This modified image layer name appears in the layers panel of QGIS but the image does not appear on the map.
Regards.
https://www.qgistutorials.com/en/docs/georeferencing_basics.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210420/55ba8291/attachment.html>
